Calculation Icon Properties
Revision as of 14:48, 3 January 2023 by MartinW (talk | contribs)
<sidebar>Sidebar: Icon Properties</sidebar>
Btn Calculation.gif Gen Calculation Flowchart Icon 01.png Gen Calculation Icon Properties 01.png
Calculation icons allow the modification of variables. They can be used to check inputs and to create outputs.
Display Name
Calculations
One or more lines of calculations can be entered into this box.
All calculations must consist of the name of an existing variable, and equals sign and an expression made up from numbers, variables and the following operators:
(, ) - Parentheses.
=, <> != - Equal to, Not equal to.
+, -, *, /, % - Addition, Subtraction, Multiplication, Division & Modulus.
<, <=, >, >= - Less than, Less than or equal to, Greater than, Greater than or equal to.
>>, << - Shift right, Shift left.
~, &, |, ^ - Bitwise NOT, AND, OR, Exclusive OR
NOT,AND,OR,XOR - Bitwise NOT, AND, OR, Exclusive OR
&&, ||, ! - Logical AND, OR, NOT
Numeric values can be in decimal (unmarked) or in HEX format (preceded by 0x) or in Binary format (preceded by 0b) e.g. 85 or 0x55 or 0b01010101.
Assuming that the variables have been previously defined, all the following are valid calculation lines.
DELAY = DELAY + 1
DELAY = (MYVAR + 3) * 3
NEXTBIT = LASTBIT >> 2 & MASK
AANDB = PORT_A AND PORT_B
INVX = NOT X
$PORTA = $PORTA + 1
$pin39 = $A2
$pin2 = 1
The $ donates a pin or a port that can now be used within calculations.
If any the variables don't exist, then Flowcode will ask if you would like to create the missing variable.
File:Gen Calculation Icon Properties 02.png
Variable and Function Box
This section is used to either select a variable or access a list of the available functions. You can reference ports directly or select from a list of available Global or Local variables. You can also view the list of available functions for mathematical and string functions.
Video instructions
See the Calculation video to learn how to use Calculation icon correctly with valid syntax, variables and expressions.
{{#ev:youtube|eycBIVJJiLc|640}}
