Component: Bluetooth (RN4677) (RN4677) (Wireless)
Author | Matrix Ltd. |
Version | 1.4 |
Category | Wireless |
Bluetooth (RN4677) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here for the component source code: FC_Comp_Source_Bluetooth_RN4677.fcfx
SendString |
Sends a string to the Bluetooth module. | |
Text |
SendCR |
Return |
LeaveCommandMode |
Leaves command mode allowing data to be passed back and forth, | |
Return |
ReadString |
Copies the incoming data from the data string array to a local string variable. | |
NumBytes |
Maximum number of bytes to try and read | |
Return |
SendByte |
Sends a single data byte out to the Bluetooth module. | |
Data |
Return |
EnterCommandMode |
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK | |
Return |
GetMACAddress |
Gets the local Bluetooth device MAC address. | |
Return |
Initialise |
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. | |
Return |
