Component: Bluetooth (RN4677) (RN4677) (Wireless)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.4 |
Category | Wireless |
Bluetooth (RN4677) component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_RN4677.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_RN4677.fcfx
ConnectToMAC
EnterCommandMode
EnterCommandMode | |
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK | |
- BOOL | Return |
GetMACAddress
GetMACAddress | |
Gets the local Bluetooth device MAC address. | |
- STRING | Return |
Initialise | |
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. | |
- BYTE | Return |
LeaveCommandMode
LeaveCommandMode | |
Leaves command mode allowing data to be passed back and forth, | |
- VOID | Return |
ReadString
ReadString | |
Copies the incoming data from the data string array to a local string variable. | |
- BYTE | NumBytes |
Maximum number of bytes to try and read | |
- STRING | Return |
ReceiveByte
SendByte
SendByte | |
Sends a single data byte out to the Bluetooth module. | |
- BYTE | Data |
- VOID | Return |
SendCommand
SendString
SendString | |
Sends a string to the Bluetooth module. | |
- STRING | Text |
- BYTE | SendCR |
- VOID | Return |
WaitForStringValue
