Component: DC Motor (Mechatronics)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Mechatronics
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here for the component source code: FC_Comp_Source_DCMotor_2d.fcfx
DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master. FC6 Icon.png DALI Slave Example1
For a DALI Master example see: Component: DALI Master (Comms: System)
Fc9-comp-macro.png Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Fc9-comp-macro.png Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Fc9-comp-macro.png Disable
Disable the motor output
Fc9-comp-macro.png Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
Fc9-u16-icon.png - UINT Duty
Sets the motor power for PWM or H-Bridge outputs
Fc9-comp-macro.png Enable
Enables the motor output
Fc9-comp-macro.png Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
Fc9-comp-macro.png GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
Fc9-conn-icon.png Control Type
Fc9-type-16-icon.png Control Method
Controls how the motor is controlled. On/Off requires output pins PWM requires a hardware PWM channel H-Bridge requires a hardware H-Bridge channel
Fc9-type-16-icon.png Bridge Type
Fc9-type-16-icon.png Enable Method
Decides how the motor outputs are enabled.
Fc9-type-5-icon.png PinA
First control pin - set 'pattern' properties below to set the pin's function.
Fc9-type-5-icon.png PinB
Second control pin - set 'pattern' properties below to set the pin's function.
Fc9-type-16-icon.png Forwards Pattern
The state of pins A and B required to drive the motor in a forwards direction.
Fc9-type-16-icon.png Reverse Pattern
States of pins A and B required to drive the motor in a reverse direction.
Fc9-type-16-icon.png Coast Pattern
States of pins A and B required to stop the motor.
Fc9-type-16-icon.png Brake Pattern
Fc9-conn-icon.png Simulation Settings
Fc9-type-2-icon.png Label Colour
Fc9-type-15-icon.png Speed
Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
