| Author
Matrix TSL
| Version
1.3
| Category
Robotics
A component to allow all the features of the Formula AllCode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Please click here to view the component source code (Beta): FC_Comp_Source_FA_Source_P4.fcfx
PlayNote
| Outputs a single tone from the onboard speaker for the period specified.
- UINT
Note
| Sets the pitch of the note in Hz. Range: 1 - 10000
- UINT
Time
| Time period to play the note for in milliseconds. Range: 0 - 65535 ms
LEDOn
| Switches on a single LED on the front of the Formula Allcode.
- BYTE
LED
| Which LED to switch on, range 0-7
BluetoothTransmit
| Sends a byte via the Bluetooth data connection.
- BYTE
Data
LCDPrintString
| Prints a string to the graphical LCD.
- BYTE
X
| The horizontal start pixel. Range 0-127
- BYTE
Y
| Y coordinate to print the string. Range 0-31
- STRING
Data
- UINT
Transparent
LogoConfigure
| The Logo movement may sometimes be slightly off in terms of distance or angle. Before tweaking the factory values check that the wheels are pushed well onto their shafts but not tight against the FA body. Also check the tyre is on the wheel correctly.
- FLOAT
Distance
| mm per encoder step. default = 0.32
- FLOAT
Angle
| mm of travel per degree. default = 0.7295
Stop
| Stops both motors.
ReadBattery
| Reads the current voltage level from the LiPo battery. Return value is the battery voltage in Volts. Take care not to run the battery too low. Voltages lower than 3.4V may damage the battery.
- FLOAT
LEDOff
| Switches off a single LED on the front of the Formula Allcode.
- BYTE
LED
LCDPrintNumber
| Prints a numeric value to the graphical LCD.
- BYTE
X
- BYTE
Y
- UINT
Number
- BYTE
Transparent
LEDWrite
| Allows control of all 8-LEDs on the front of the Formula Allcode.
- BYTE
LED_Byte
| 8-bit binary value to write to the 8 LEDs
BluetoothCheckConnection
| Checks the status of the Bluetooth connection. Returns 0 for not paired and 1 for paired.
- BYTE
ReadMic
| Reads the current audio signal level from the on-board microphone. Return value range: 0 to 4095
- UINT
AudioQueueLength
| Retreives the current length of valid data within the audio queue
- UINT
AudioAddToBuffer
| Writes a value to the 16-bit audio output buffer.
- UINT
Data
ReadSwitch
| Reads the value of one of the switches from the front of the Formula Allcode.
- BYTE
Switch
| Which switch do we want to read 0=Left, 1=Right
- BYTE
CheckLine
| Checks to see if a line sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE
Sensor
| Range: 0 to 1 - 0=Left, 1=Right
- BYTE
AudioStreamControl
| Allows control of the audio output functionality via the onboard speaker. Data is loaded into the audio output buffer using the AddToBuffer function.
- BYTE
Mode
| 0=Off, 8=8-bit Mode, 16=16-bit Mode
- BYTE
SampleRate
| Sets the sample rate 0=8KHz, 1=16KHz
SpinLeft
| Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
- BYTE
Power
| Amount of power to use to drive motor. Range 0-100
LogoTurnLeft
| Rotates the robot left by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT
Angle
| Angle in degrees you wish to rotate. Range 1-65536
Forward
| Drives both motors of the formula flowcode forwards with the power specified.
- BYTE
Power
LCDWriteByte
- BYTE
Data
- BYTE
X
- BYTE
Y
BluetoothReceive
| Attempt to read a byte from the Bluetooth receive queue.
- BYTE
LCDDrawLine
| Draws a line on the LCD.
- BYTE
X1
| Range 0-127
- BYTE
Y1
| Range 0-31
- BYTE
X2
| Range 0-127
- BYTE
Y2
| Range 0-31
BluetoothQueueLength
| Reads the length of received Bluetooth data in bytes.
- UINT
BluetoothTransmitString
| Sends a string via the Bluetooth data connection.
- STRING
Data
LCDBacklight
| Controls the brighness of the LCD backlight
- BYTE
Brightness
| Range: 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
AudioReadFromBuffer
| Allows the audio buffer to be used for other streaming data such as recording the mic.
- UINT
ReadLineSensor
| Reads the analogue value from the specified IR line sensor. Return value range: 0 to 4095 4095 represents the object is reflecting the most light.
- BYTE
- UINT
LogoTurnRight
| Rotates the robot right by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
- UINT
Angle
SpinRight
| Spins the formula flowcode on the spot in a clockwise direction as seen from above.
- BYTE
Power
CheckIR
| Checks to see if a IR sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
- BYTE
Sensor
| Range: 0 to 7 - 0=Left, 1=Front Left, 2=Front, 3=Front Right, 4=Right, 5=Rear Right, 6=Rear, 7=Rear Left
- BYTE
LCDPlotPixel
| Allows a single pixel on the LCD to be set or cleared.
- BYTE
X
| Sets the X coordinate - Range 0-127
- BYTE
Y
| Sets the Y coordinate - Range 0-31
LCDSetBackgroundColour
| Sets the pixel colour to drive the LCD. Default colour is 1 where a set pixel is black and the background is white.
- BYTE
Colour
| Range 0-1 : 0=White, 1=Black
ReadIRSensor
| Reads the analogue value from the specified IR distance sensor. Return value range: 0 to 4095 4095 represents the object is very close.
- BYTE
- UINT
SetMotors
| Sets the speed and direction of the Formula Allcode motors.
- INT
Left
| Valid Range = -100 to 100
- INT
Right
LogoBackwards
| Drives the robot backward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT
Distance
| Distance you want to robot to drive in mm. Range 1-65535
EncoderReset
| Resets the encoder counters to 0
Reverse
| Drives both motors of the formula flowcode backwards with the power specified.
- BYTE
Power
WaitForSwitch
| Waits for the specified switch to be pressed.
- BYTE
Switch
| Which switch do we want to wait for 0=Left, 1=Right, 2=Either, 3=Both
ReadLDR
| Reads the current light level from the on board light sensor. Return value range: 0 to 4095 4095 represents the maximum level of light and 0 represents the minimal level of light.
- UINT
LCDDrawRectangle
| Draws a rectange on the LCD.
- BYTE
X1
| Range 0-127
- BYTE
Y1
| Range 0-31
- BYTE
X2
| Range 0-127
- BYTE
Y2
| Range 0-31
- BYTE
Transparent
| Sets the transparency of the box, 0=Box contains background colour, 1=Box contains previous pixel data
- BYTE
Solid
| Chooses to fill the box with colour, 0=Box contains transparency data, 1=Box contains foreground colour
EncoderReadCount
| Reads one of the motor encoder counters. Each encoder count is equal to 0.314159 mm.
- BYTE
| 0 = LeftCount, 1=RightCount
- UINT
CheckUSB
| Checks to see if a USB cable is connected to the robot. Returns 0 for no connection and 1 for an active connection.
- BYTE
LCDSetForegroundColour
- BYTE
Colour
| Starts up the Formula Allcode PWM for motor control and performs the wait for button press if enabled.
LogoSetSpeed
| Sets the cruise speed for LOGO type macros. Default speed 20%.
- BYTE
Speed
| Range 1-100, Default 60
LogoForwards
| Drives the robot forward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
- UINT
Distance
LCDClear
| Clears the contents of the graphical LCD.
Wait For Button
| Determines if the program will automatically wait for one of the front switches to be pressed before executing the program. Ran as part of the initialise function after the various components have been initialised.
Show Creation Info
| Specifies what information is shown to the user on calling the initialise function. The time and date shown are the compilation time and date to help pinpoint the firmware version.
Bluetooth Reset
| Decides if the Bluetooth data connection can reset the Formula AllCode. Used by mLoader when programming via Bluetooth to allow reprogramming without having to physically touch the robot. To ensure programming security set this option to No.
Use Motor Feedback
| Controls when the motor feedback is used. No - Speed control feedback is not used for SetMotors commands. Yes - Speed control feedback is used for the SetMotors commands. SetMotors commands include Forward, Backward, SpinLeft, SpinRight as well as SetMotors itself. Logo functions always use feedback.
IR Simulation
IR Simulation Mode
| Controls how the IR sensors are modelled in simulation. Linear is the legacy mode and works as it has always done. Exponential attempts to provide a more accurate reading which is closed to response of the real world hardware,
IR Thresholds (CheckIR macro)
IR Distance
| IR Threshold used with the CheckIR macro
Line Sensitivity
Simulation Properties
Sim Speed (1 - 100)
| Sets the simulated amount of movement relative to the speed of the Formula Allcode.
Timer Interval (ms)
| Interval in milliseconds between each simulated movement of the Formula Allcode robot.
Collision Method
| Select which objects the robot sensors will interact with.
Light Source
| Panel object specified as the simulation light source. Used when simulating "find the light" type tasks.
Addon Mechanics
| Useful if you are creating add-ons to the robot which you want to be able to simulate. Point the property at the group containing the Formula Allcode and the additional mechanics. Otherwise leave blank to maintain the normal simulation functionality.
PlayNote
- UINT
Note
- UINT
Time
LEDOn
- BYTE
LED
BluetoothTransmit
- BYTE
Data
LCDPrintString
- BYTE
X
- BYTE
Y
- STRING
Data
- UINT
Transparent
LogoConfigure
- FLOAT
Distance
- FLOAT
Angle
Stop
| Stops both motors.
ReadBattery
- FLOAT
LEDOff
- BYTE
LED
LCDPrintNumber
- BYTE
X
- BYTE
Y
- UINT
Number
- BYTE
Transparent
LEDWrite
- BYTE
LED_Byte
- BYTE
ReadMic
- UINT
AudioQueueLength
- UINT
AudioAddToBuffer
- UINT
Data
ReadSwitch
- BYTE
Switch
- BYTE
CheckLine
- BYTE
Sensor
- BYTE
AudioStreamControl
- BYTE
Mode
- BYTE
SampleRate
SpinLeft
- BYTE
Power
LogoTurnLeft
- UINT
Angle
Forward
- BYTE
Power
LCDWriteByte
- BYTE
Data
- BYTE
X
- BYTE
Y
BluetoothReceive
- BYTE
LCDDrawLine
- BYTE
X1
| Range 0-127
- BYTE
Y1
| Range 0-31
- BYTE
X2
| Range 0-127
- BYTE
Y2
| Range 0-31
- UINT
- STRING
Data
LCDBacklight
- BYTE
Brightness
AudioReadFromBuffer
- UINT
ReadLineSensor
- BYTE
- UINT
LogoTurnRight
- UINT
Angle
SpinRight
- BYTE
Power
CheckIR
- BYTE
Sensor
- BYTE
LCDPlotPixel
- BYTE
X
- BYTE
Y
- BYTE
Colour
ReadIRSensor
- BYTE
- UINT
SetMotors
- INT
Left
- INT
Right
LogoBackwards
- UINT
Distance
EncoderReset
Reverse
- BYTE
Power
WaitForSwitch
- BYTE
Switch
ReadLDR
- UINT
LCDDrawRectangle
- BYTE
X1
| Range 0-127
- BYTE
Y1
| Range 0-31
- BYTE
X2
| Range 0-127
- BYTE
Y2
| Range 0-31
- BYTE
Transparent
- BYTE
Solid
EncoderReadCount
- BYTE
- UINT
CheckUSB
- BYTE
- BYTE
Colour
LogoSetSpeed
- BYTE
Speed
LogoForwards
- UINT
Distance
LCDClear
Wait For Button
Show Creation Info
Bluetooth Reset
Use Motor Feedback
IR Simulation
IR Simulation Mode
IR Distance
Line Sensitivity
Sim Speed (1 - 100)
Timer Interval (ms)
Collision Method
Light Source
Addon Mechanics
