Component: PWM Free (Peripheral CAL)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.3 |
| Category | Peripheral CAL |
PWM Free component
A low level implementation giving direct access to the CAL
Please click here to view the component source code (Beta): FC_Comp_Source_PWM_Free.fcfx
| GetValue | |
| Returns Named property Value | |
| Name | |
| ChangePeriod | |
| Change the Period (and prescaler) for this PWM Channel | |
| period | |
| period value PIC/AVR: 0-255 16-bit PIC: 0-65535 | |
| prescaler | |
| prescaler 1,4,16,64 | |
| Disable | |
| Disable this PWM Channel | |
| SetDuty8Bit | |
| Set the Duty cycle (0-255) for this PWM Channel | |
| duty | |
| duty value 0 - 255 | |
| Enable | |
| Enable this PWM Channel | |
| SetValue | |
| Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
| Name | |
| Value | |
| SetDuty10Bit | |
| Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535 | |
| duty | |
| Duty value 0 - 1023 | |
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
| GetValue | |
| Name | |
| ChangePeriod | |
| period | |
| prescaler | |
| Disable | |
| SetDuty8Bit | |
| duty | |
| Enable | |
| SetValue | |
| Name | |
| Value | |
| SetDuty10Bit | |
| duty | |
| GetList | |
| Name | |
