Component: SPI Free (Peripheral CAL)
Revision as of 15:16, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Peripheral CAL
SPI Free component
A low level implementation giving direct access to the CAL
Please click here to view the component source code (Beta): FC_Comp_Source_SPI_Free.fcfx
Slave_Uninit
Uninitialise the Slave
GetValue
Reads Named property Value.
- STRING Name
- STRING Return
Slave_Init
Initialise the Slave
Master_Uninit
Uninitialise the Master
Master_Byte
Sends and receives a data byte
- BYTE DataOut
GetConsoleHandle
Returns a handle to the console used by this component
- HANDLE Return
Slave_TxByte
Sets the data to be transmitted
- BYTE Data
Slave_RxByte
Returns the data received
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
Master_Init
Initialise the Master
GetList
returns Named property list
- STRING Name
- STRING Return
Component Enable
SPI Channel selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
Prescale
Prescale option selector
Clock Polarity
Clock Phase
Sample Point
Data bit read sample point
Slave_Uninit
GetValue
- STRING Name
- STRING Return
Slave_Init
Master_Uninit
Master_Byte
- BYTE DataOut
GetConsoleHandle
- HANDLE Return
Slave_TxByte
- BYTE Data
Slave_RxByte
SetValue
- STRING Name
- STRING Value
SetPrescaler
- BYTE Prescaler
Master_Init
GetList
- STRING Name
- STRING Return
Component Enable
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
Prescale
Clock Polarity
Clock Phase
Sample Point
