Component: ADC (CAL) (Misc)
Revision as of 15:19, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
ADC component
CAL - Code Abstraction Layer A low level implementation giving direct access to the analogue to digital converter peripheral.
Please click here to download the component source project: FC_Comp_Source_ADC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ADC.fcfx
Fc9-comp-macro.png GetValue
Gets the Name property value
Fc9-string-icon.png - STRING Name
The name of the property
Fc9-comp-macro.png Disable
Disables the current ADC channel Call this once sampling is complete
Fc9-comp-macro.png Enable
Enables sampling of the ADC channel This is called every time a new ADC channel needs configuring to ADC mode [u]Only one ADC channel may be enabled at any time[/u] When sampling is complete, call Disable() to restore the pin
A value >= 0 specifying the ADC channel
Fc9-u8-icon.png - BYTE Conv_Speed
Chip-specific rate of change read from the FCD <ADC.ConfSpeed>
Fc9-u8-icon.png - BYTE Vref
0 to disable Vref mode, else 1
Fc9-u8-icon.png - BYTE T_Charge
Aquisition time to wait in micro seconds
Fc9-comp-macro.png Sample
Blocking call to read a sample on the currently enabled channel
Fc9-u8-icon.png - BYTE Sample_Mode
True to enable full-width sample (10 or 12 bits), else false for 8 bit
Fc9-comp-macro.png SetValue
Sets the Value for the named property
Name of property to update
Fc9-string-icon.png - STRING Value
The new value for the property
Fc9-comp-macro.png GetList
Fc9-type-16-icon.png Peripheral
Fc9-type-6-icon.png Channel ADC Pin
ADC Channel number
Fc9-type-16-icon.png Vref Option
selects the reference voltage option
Fc9-type-14-icon.png Vref+ (x10mV)
sets the value of the reference voltage (used for conversion calculations)
Fc9-type-16-icon.png Acq Time
ADC Aquisition time
Fc9-type-7-icon.png Use FRC clock
Uses the internal fixed RC clock to perform ADC conversions. In most cases it is better to switch this off and use the conversion speed to ensure sampling is consistent.
Fc9-type-16-icon.png Conv Speed
Conversion speed option
Fc9-type-14-icon.png Type
Fc9-type-14-icon.png Bits
Fc9-type-7-icon.png Custom Pins
Fc9-type-7-icon.png Has DMA
Fc9-type-7-icon.png Use DMA
Fc9-type-16-icon.png DMA Trigger
Fc9-type-7-icon.png Has Scanning
Fc9-type-7-icon.png Use Scanning
Fc9-conn-icon.png Simulation
ADC Channel number
ADC Aquisition time
ADC Channel number
ADC Aquisition time
