Author
Matrix TSL
Version
2.0
Category
Misc
ADC component
CAL - Code Abstraction Layer A low level implementation giving direct access to the analogue to digital converter peripheral.
Please click here to download the component source project: FC_Comp_Source_ADC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ADC.fcfx
GetValue
Gets the Name property value
- STRING
Name
The name of the property
- STRING
Disable
Disables the current ADC channel Call this once sampling is complete
Enable
Enables sampling of the ADC channel This is called every time a new ADC channel needs configuring to ADC mode [u]Only one ADC channel may be enabled at any time[/u] When sampling is complete, call Disable() to restore the pin
- BYTE
A value >= 0 specifying the ADC channel
- BYTE
Conv_Speed
Chip-specific rate of change read from the FCD <ADC.ConfSpeed>
- BYTE
Vref
0 to disable Vref mode, else 1
- BYTE
T_Charge
Aquisition time to wait in micro seconds
Sample
Blocking call to read a sample on the currently enabled channel
- BYTE
Sample_Mode
True to enable full-width sample (10 or 12 bits), else false for 8 bit
- UINT
SetValue
Sets the Value for the named property
- STRING
Name
Name of property to update
- STRING
Value
The new value for the property
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
selects the reference voltage option
Vref+ (x10mV)
sets the value of the reference voltage (used for conversion calculations)
Acq Time
ADC Aquisition time
Use FRC clock
Uses the internal fixed RC clock to perform ADC conversions. In most cases it is better to switch this off and use the conversion speed to ensure sampling is consistent.
Conv Speed
Conversion speed option
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
