Component: PWM Free (Peripheral CAL)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Peripheral CAL
PWM Free component
A low level implementation giving direct access to the CAL
Please click here to download the component source project: FC_Comp_Source_PWM_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PWM_Free.fcfx
GetValue
Returns Named property Value
- STRING Name
- STRING Return
ChangePeriod
Change the Period (and prescaler) for this PWM Channel
- UINT period
period value PIC/AVR: 0-255 16-bit PIC: 0-65535
- UINT prescaler
prescaler 1,4,16,64
Disable
Disable this PWM Channel
SetDuty8Bit
Set the Duty cycle (0-255) for this PWM Channel
- BYTE duty
duty value 0 - 255
Enable
Enable this PWM Channel
SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
- STRING Name
- STRING Value
SetDuty10Bit
Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535
- UINT duty
Duty value 0 - 1023
GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
- STRING Name
- STRING Return
PWM Channel selector
Alt Pin Enable
Alternative Pin Enable (if available on target device)
Port
Period Register
PWM Period Register value
Prescaler Divide
Prescaler Divider value
PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Clock Speed
Period (uS)
Frequency (KHz)
Master Divider
GetValue
- STRING Name
- STRING Return
ChangePeriod
- UINT period
- UINT prescaler
prescaler 1,4,16,64
Disable
SetDuty8Bit
- BYTE duty
duty value 0 - 255
Enable
SetValue
- STRING Name
- STRING Value
SetDuty10Bit
- UINT duty
Duty value 0 - 1023
GetList
- STRING Name
- STRING Return
Alt Pin Enable
Port
Period Register
Prescaler Divide
PWM Timer
Clock Speed
Period (uS)
Frequency (KHz)
Master Divider
GetValue
- STRING Name
- STRING Return
ChangePeriod
- UINT period
- UINT prescaler
prescaler 1,4,16,64
Disable
SetDuty8Bit
- BYTE duty
duty value 0 - 255
Enable
SetValue
- STRING Name
- STRING Value
SetDuty10Bit
- UINT duty
Duty value 0 - 1023
GetList
- STRING Name
- STRING Return
Alt Pin Enable
Port
Period Register
Prescaler Divide
PWM Timer
Clock Speed
Period (uS)
Frequency (KHz)
Master Divider
GetValue
- STRING Name
- STRING Return
ChangePeriod
- UINT period
- UINT prescaler
prescaler 1,4,16,64
Disable
SetDuty8Bit
- BYTE duty
duty value 0 - 255
Enable
SetValue
- STRING Name
- STRING Value
SetDuty10Bit
- UINT duty
Duty value 0 - 1023
GetList
- STRING Name
- STRING Return
Alt Pin Enable
Port
Period Register
Prescaler Divide
PWM Timer
Clock Speed
Period (uS)
Frequency (KHz)
Master Divider
