Component: UART Free (Peripheral CAL)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Peripheral CAL
UART Free component
A low level implementation giving direct access to the CAL
Please click here to download the component source project: FC_Comp_Source_UART_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Free.fcfx
UpdateBaud
Changes the UART Baud rate. 0 = 1200 / 1 = 2400 / 3 = 4800 / 3 = 9600 / 4 = 19200 / 5 = 38400 6 = 57600 / 7 = 115200
- BYTE new_baud
The new baud rate (0=1200, 7=115200)
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Receive
Receive a Character
- BYTE Timeout
Period to wait for the character to be received
- INT Return
Send
Send the Character
- UINT Char
The Character to send
GetConsoleHandle
- HANDLE Return
Init
Initialize the component with the specified properties
Delay
Software UART Bit Delay
SetValue
set Value of Named property
- STRING Name
- STRING Value
Uninit
Un-initialize the UART and release the resources
GetList
Gets Named property List
- STRING Name
- STRING Return
UART Channel selector
TX
RX
Baud Options
Data Bits
Number of data bits
Return data width from Receive macro
Echo
Echo selection
Interrupt
Interrupt mode enable or disable
Flow Control
Flow Control (Handshake) enable or disable
