Component: I2C Free (Peripheral CAL)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.3 |
Category | Peripheral CAL |
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
Slave_Uninit
Slave_Uninit |
Uninitialise the Slave | |
Return |
GetValue
GetValue |
Get the Named property value. | |
Name |
Return |
Master_Stop
Master_Stop |
Output a Master Stop | |
Return |
Slave_Init
Master_Uninit
Master_Uninit |
Uninitialise the Master | |
Return |
Slave_Status
GetConsoleHandle
GetConsoleHandle |
Obtains the CAL console handle | |
Return |
Slave_TxByte
Slave_TxByte |
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last | |
Data |
Return |
Slave_RxByte
Slave_RxByte |
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More | |
Last |
Sends Ack if 0, else Nak | |
Return |
SetValue
SetValue |
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd | |
Name |
Value |
port value as string | |
Return |
Master_Init
Master_Init |
Initialise the Master | |
Return |
Master_Start
Master_Start |
Output a Master Start sequence | |
Return |
Master_TxByte
Master_TxByte |
Send a data byte | |
Data |
Return |
Master_Restart
Master_Restart |
Output a Master Restart sequence | |
Return |
Master_RxByte
GetList
GetList |
returns Named property List as filter string | |
Name |
Return |
