DSP
What is DSP
- Audio effects e.g. Echo, Reverb, Guitar Distortion, etc
- Signal Filtering
- Frequency Spectrum Analysis
- Sensor Arrays e.g. Baby Monitors, Radio Telescopes, Near/Far field
- Closed/Open Loop Control e.g. Speed, Position, Temperature, Height, Level, Angle, etc
- Modern Digital Communications
DSP Component Basics
DSP components with an arrow facing away from the component represent a memory block or buffer that can be accessed by one or more other DSP components. The number of values that can be stored and the type of values that can be stored are available via the component properties.
DSP components with an arrow facing towards the component represent a reference to the memory block created by another DSP component. The link is controlled via the component properties.
Once DSP components are linked together a line is drawn between the components.
The colour of the link line indicates the type of data that is being stored in the buffer.
Colour | Buffer Type | Range |
Black | Byte | 0 to 255 |
Red | Unsigned Int | 0 to 65,535 |
Orange | Signed Int | -32,768 to 32,767 |
Green | Unsigned Long | 0 to 4,294,967,295 |
Blue | Signed Long | -2,147,483,648 to 2,147,483,647 |
Purple | Float | 32-bit approximation of a real number |
DSP Components
DSP Inputs | ||
Input ADC | Inputs from an ADC enabled input pin | |
Input CSV | Inputs data from a file | |
Input Digital | Inputs generic digital data | |
Input Digital Pin | Inputs from a digital input pin | |
Waveform Generator | Generates cyclic or randomised waveform data | |
DSP Outputs | ||
Level | Monitors data statistics like peaks and troughs | |
Output CSV | Outputs to a file | |
Output DAC | Outputs to a DAC enabled output pin | |
Output Digital | Outputs generic digital data | |
Output Digital Pin | Outputs to a digital output pin | |
Output PWM | Outputs to a PWM enabled output pin | |
DSP Operators | ||
Adder | Adds together two or more DSP signals | |
Averager | Takes an average of two or more DSP signals | |
Deinterlace | Breaks apart a single interlaced DSP signal into sub signals | |
Delay | Adds a fixed or variable delay in the DSP signal | |
Fast Fourier Transform (FFT) | Converts time based DSP signal data into Frequency based | |
Filter | Provides digital filtering on a DSP signal | |
Interlace | Combines multiple DSP signals into a single DSP signal | |
Kalman Filter | Provides predictive digital filtering on a DSP signal | |
Math | Mathematical operations with two DSP signals (+,-,/,* etc) | |
Median | Provides median filtering on a DSP signal to get rid of spurious data samples | |
Multiplex | Allows a number of DSP signals to be selected and switched between | |
Offset | Adds a fixed or variable offset to a DSP signal | |
On/Off Control | Provides simple on/off closed loop control | |
PID Control | Provides P/PI/PID closed loop control | |
Rectifier | Allows a DSP signal to be flipped below a certain threshold | |
Scale | Applies a scaler to a DSP signal | |
Simulated Control Load | Simulates an active load such as a heater or motor to allow simulation of closed loop systems |
Component Macros
A typical DSP system will use a timer interrupt macro to maintain a steady rate on which everything happens. The timer interrupt will do things like any analogue sampling and may also call the DSP component functions in order. Based on this methodology we have created two variants of most of the DSP component macros in the form of Function and FunctionArray. These allow two different ways of working with the DSP component. These methods can be mixed and matched as necessary to allow your program to run at the optimum speed and throughput.
Single
The Function type macros allow a single value in the DSP buffer to be processed. Behind the scenes this performs the hardware macro functionality on the next buffer value.
The tick based functions are designed to operate inside the interrupt function at sample rate. This allows your DSP code to utilize more of the system runtime but means you have less time for other functions such as refreshing a display. Because you are only processing a single value in a buffer rather then an entire buffer the function code is much shorter. This also has a second impact that there is a minimal delay in data being held in the buffer before being processed. The location inside the buffer is automatically tracked for you by the master buffer index.
Array
The Array type macros allow the entire DSP buffer to be processed at once. Behind the scenes this involves a loop and we cycle through all of the values in the buffer performing the macro function. Some components such as the Fast Fourier Transform (FFT) only have the Array version of the macro as the FFT calculations can only work with a buffer full of data.
The standard array based functions are designed to process a complete buffer in one operation. Care should be taken that the processing time is no longer then a single interrupt period.
This method gives you free time between interrupts where other functions can be performed such as updating the GUI on a display. The longer the buffers, the more time you get between having to process the trigger code but the downside is that the trigger code will take more time to process.
Combining Single and Array Calls
The single style approach is similar to using the trigger style approach with a buffer size of one so really the design of the system is entirely up to what you feel most comfortable with and what best suits your application.
