Author
Matrix TSL
Version
1.0
Category
Mechatronics
Kinematics Arm component
Demonstrates the principals of kinematics using a user configurable robot arm. Provides full simulation of the movements of the arm and the calculations of the axis positions and rotations.
Please click here to download the component source project: FC_Comp_Source_KinematicsArm.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_KinematicsArm.fcfx
Example program showing a six axis robot arm with a gripper, controlled using sliders on the 2d panel.
Kinematics Arm Demo
ForwardKinematics
ForwardKinematics
Uses the current joint angles and positions to calculate the XYZ and rotation of each of the subsequent linking joints.
GetJointPosition
GetJointPosition
Gets the XYZ position of the selected joint axis.
- BYTE
Axis
Range: 0 to NumAxis-1 where NumAxis-1 = end tool location
- FLOAT
XYZ
GetJointRotation
GetJointRotation
Gets the XYZ rotation of the selected joint axis.
- BYTE
Axis
- FLOAT
XYZ
SetGripper
SetGripper
Open or close the gripper
- BYTE
Position
0=Fully Closed, 255=Fully Open
SetJoint
SetJoint
Sets the angle or translation of the specified joint axis.
- BYTE
Axis
Range: 0 to NumAxis -1
- FLOAT
Value
Angle or dimension
- BOOL
Type
0=Absolute, 1=Incremental
Axis
Number of axis
Axis 0
Axis Type
Sets the movement type of the axis
Colour
Specifies the fill colour of the shape
DH Parameters
d
the distance between the previous x-axis and the current x-axis, along the previous z-axis
Theta
the angle around the z-axis between the previous x-axis and the current x-axis
a / r
the length of the common normal, which is the distance between the previous z-axis and the current z-axis
alpha
the angle around the common normal to between the previous z-axis and current z-axis
Axis 1
Axis Type
Colour
DH Parameters
d
Theta
a / r
alpha
Axis 2
Axis Type
Colour
DH Parameters
d
Theta
a / r
alpha
Axis 3
Axis Type
Colour
DH Parameters
d
Theta
a / r
alpha
Axis 4
Axis Type
Colour
DH Parameters
d
Theta
a / r
alpha
Axis 5
Axis Type
Colour
DH Parameters
d
Theta
a / r
alpha
Gripper
Show Gripper
Colour
Link Mechanics
Show Links
Determines if the links between axis are shown.
Link Colour
