Component: Switch Push Button (Switch)
| Version | 15.0 |
| Category | Switch |
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
Library Version, Component Version, Date, Author, Info 15, 15.0, 30-07-24, MW, Fixed a bug to make sure switch starts in the off position 15, 15.0, 18-08-24, MW, Added option for simulation only 15, 15.0, 30-07-24, MW, Fixed a bug preventing custom lable posistion from updating on the fly
 Switch
Switch
(5V / 11K) * 10K = 4.54545V
Note: if you want to use switch functions e.g. Active Low or debounce ,you must use the ReadState function and not use just an input.
ReadState
|   | ReadState |
| Reads the button state as 0 for released or 1 for pressed Performs debounce if required | |
|  - BYTE | Return |
SetState
|   | SetState |
| Sets the switch to be on or off. | |
|  - BOOL | State |
| The new state of the switch (true=on, false=off) | |
|  - VOID | Return |
WaitUntilHigh
|   | WaitUntilHigh |
| Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity | |
|  - VOID | Return |
WaitUntilLow
|   | WaitUntilLow |
| Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity | |
|  - VOID | Return |
Please click here to download the component source project: FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
