Component: MIAC GPS (MIAC: Addon Modules)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author
Category MIAC: Addon Modules
MIAC GPS component
GPS Addon expansion module for MIAC System
FREE
FAT_OpenFile
- STRING Filename
GPS_Read_Longitude
- FLOAT Return
GPS_Read_GroundSpeed
- FLOAT Return
GPS_Read_Latitude
- FLOAT Return
GPS_Read_DilutionOfPrecision
- FLOAT Return
FAT_Init
GPS_Read_Over_Ground
- FLOAT Return
GPS_Read_UTC_Date
- BYTE unit
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
GPS_HorizontalDilutionOfPrecision
- FLOAT Return
FAT_ScanCurrentFolder
- UINT idx
- BYTE type
Scan type
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
GPS_Is_Data_Valid
FAT_AppendStringToFile
- STRING Text
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
FAT_OpenFolder
- STRING Folder
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
FAT_MoveToNextFileSector
- BYTE force
force next sector
FAT_ReadByteFromScan
- UINT idx
GPS_Read_NumberOfSatellites
FAT_ReadFileLength
FAT_CreateFile
- STRING Filename
MIAC_Module_PushData
- BYTE Data
GPS_Read_VerticalDilutionOfPrecision
- FLOAT Return
FAT_WriteFileSector
GPS_Read_Altitude
- FLOAT Return
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
FAT_ReadByteFromBuffer
- UINT address
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
FAT_WriteByteToBuffer
- UINT address
- BYTE data
FAT_ReadFileSector
FAT_DeleteFile
- STRING Filename
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
Initialize
Forces a software reset on the module
GPS_Read_UTC_Time
- BYTE unit
DigitalInput
Read the value of a terminal
- BYTE Terminal
Module Type
Module Address
Simulations
