Component: MIAC GPS (MIAC: Addon Modules)
Jump to navigationJump to searchAuthor | |
Version | 1.0 |
Category | MIAC: Addon Modules |
MIAC GPS component
GPS Addon expansion module for MIAC System
FREE
FAT_OpenFile | |
- STRING | Filename |
- BYTE | Return |
GPS_Read_Longitude | |
- FLOAT | Return |
GPS_Read_GroundSpeed | |
- FLOAT | Return |
GPS_Read_Latitude | |
- FLOAT | Return |
GPS_Read_DilutionOfPrecision | |
- FLOAT | Return |
FAT_Init | |
- BYTE | Return |
GPS_Read_Over_Ground | |
- FLOAT | Return |
GPS_Read_UTC_Date | |
- BYTE | unit |
- BYTE | Return |
MIAC_Module_SetData | |
- BYTE | Count |
- BYTE | D0 |
- BYTE | D1 |
- BYTE | D2 |
- BYTE | D3 |
- BYTE | D4 |
- BYTE | D5 |
- VOID | Return |
GPS_HorizontalDilutionOfPrecision | |
- FLOAT | Return |
FAT_ScanCurrentFolder | |
- UINT | idx |
- BYTE | type |
Scan type | |
- BYTE | Return |
MIAC_Module_Init | |
- UINT | CAN_ID |
- VOID | Return |
MIAC_Module_GetData | |
- BYTE | Index |
- BYTE | Return |
GPS_Is_Data_Valid | |
- BYTE | Return |
FAT_AppendStringToFile | |
- STRING | Text |
- BYTE | Return |
MIAC_Module_Message | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- BYTE | Return |
MIAC_Module_WR | |
- UINT | CAN_ID |
- UINT | CMD_ID |
[[File:]] - | Count |
[[File:]] - | Start |
[[File:]] - | More |
- VOID | Return |
FAT_OpenFolder | |
- STRING | Folder |
- BYTE | Return |
LED_Control | |
Sets the indicator LED On (State=1) or Off (State=0) | |
- BYTE | State |
- VOID | Return |
FAT_MoveToNextFileSector | |
- BYTE | force |
force next sector | |
- BYTE | Return |
FAT_ReadByteFromScan | |
- UINT | idx |
- BYTE | Return |
GPS_Read_NumberOfSatellites | |
- BYTE | Return |
FAT_ReadFileLength | |
- UINT | Return |
FAT_CreateFile | |
- BYTE | Return |
MIAC_Module_PushData | |
- BYTE | Data |
- VOID | Return |
GPS_Read_VerticalDilutionOfPrecision | |
- FLOAT | Return |
FAT_WriteFileSector | |
- BYTE | Return |
GPS_Read_Altitude | |
- FLOAT | Return |
DigitalOutput | |
Set a Terminal Output to High (Value=1) or Low (Value=0) | |
- BYTE | Terminal |
- BYTE | Value |
- BYTE | Return |
FAT_ReadByteFromBuffer | |
- UINT | address |
- BYTE | Return |
MIAC_Module_GetAck | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- UINT | TimeOut |
- BYTE | Return |
FAT_WriteByteToBuffer | |
- UINT | address |
- BYTE | data |
- VOID | Return |
FAT_ReadFileSector | |
- BYTE | Return |
FAT_DeleteFile | |
- BYTE | Return |
AnalogInput | |
Read the ADC value of a Terminal Returns 12 bit ADC reading | |
- BYTE | Terminal |
Terminal number to be read | |
- UINT | Return |
Initialize | |
Forces a software reset on the module | |
- VOID | Return |
GPS_Read_UTC_Time | |
- BYTE | unit |
- BYTE | Return |
DigitalInput | |
Read the value of a terminal | |
- BYTE | Terminal |
- BYTE | Return |
Properties | |
Module Type | |
Module Address | |
Connections | |
Simulations |
