Component: OBD2 ECU (Server) (Comms: System)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Comms: System
OBD2 ECU (Server) component
Implements an ECU side OBD-II server
Please click here to download the component source project: FC_Comp_Source_OBD2_ECU.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OBD2_ECU.fcfx
DTC_Add
DTC_Add
Adds a DTC to the store (e.g. "B1318") Checks to see if the DTC string is already in the store before adding.
- STRING DTC_String
- BOOL CheckExists
Checks to see if error code already exists
DTC_Clear
DTC_Clear
Clears the DTC store
DTC_Count
DTC_Count
Returns the number of stored DTCs
DTC_Get
DTC_Get
Get the DTC from the store at Index
- UINT Index
- STRING Return
FlushBuffer
FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
GetByte
GetByte
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty.
GetNumberBytes
GetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
Initialise the CAN network
Process
Process
Does the message processing. Call this often.
- UINT TimeElapsed
Time elapsed since last call, in mS. Can be zero for frequent calling.
Set_ECU_Name
Set_ECU_Name
Set the ECU Name
- STRING Name
Set_Engine_Coolant_Temperature
-40 to 215 (deg C)
- FLOAT Value
Value range -40 to 215 deg C
Set_Engine_Load
Set_Engine_Load
0 to 100 (%)
- FLOAT Value
Speed in RPM
Set_Engine_Speed
Set_Engine_Speed
0 to 16,383.75 (rpm)
- FLOAT Value
Speed in RPM
Set_MAF_Rate
Set_MAF_Rate
0 to 655.35 grams/sec
- FLOAT Value
MAF air flow rate in grams/sec
Set_Throttle_Position
0 - 100 (%)
- FLOAT Value
Position value as a percentage (0 - 100%)
Set_VIN
Set_VIN
Set the 17 character VIN
- STRING VIN
Set_Vehicle_Speed
Set_Vehicle_Speed
0 - 255 (km/h)
- FLOAT Value
Speed in RPM
DTC Store Size
Maximum number of DTC codes to store
VIN
17 character Vehicle Identification Number
CAN
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
SPI
CHANNEL
SPI Channel selector
MOSI
MISO
CLK
SS
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
