Component: OBD2 ECU (Server) (Comms: System)
Version | 1.0 |
Category | Comms: System |
- 1 OBD2 ECU (Server) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DTC_Add
- 5.2 DTC_Clear
- 5.3 DTC_Count
- 5.4 DTC_Get
- 5.5 FlushBuffer
- 5.6 GetByte
- 5.7 GetNumberBytes
- 5.8 Initialise
- 5.9 Process
- 5.10 Set_ECU_Name
- 5.11 Set_Engine_Coolant_Temperature
- 5.12 Set_Engine_Load
- 5.13 Set_Engine_Speed
- 5.14 Set_MAF_Rate
- 5.15 Set_Throttle_Position
- 5.16 Set_VIN
- 5.17 Set_Vehicle_Speed
- 6 Property reference
Implements an ECU side OBD-II server
Please click here to download the component source project: FC_Comp_Source_OBD2_ECU.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OBD2_ECU.fcfx
DTC_Add
DTC_Clear
DTC_Clear | |
Clears the DTC store | |
- VOID | Return |
DTC_Count
DTC_Count | |
Returns the number of stored DTCs | |
- UINT | Return |
DTC_Get
DTC_Get | |
Get the DTC from the store at Index | |
- UINT | Index |
- STRING | Return |
FlushBuffer
FlushBuffer | |
Clears the contents of the buffer and re-initialises the index locations. | |
- VOID | Return |
GetByte
GetByte | |
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty. | |
- UINT | Return |
GetNumberBytes
GetNumberBytes | |
Returns the number of valid data bytes currently inside the buffer. | |
- UINT | Return |
Initialise | |
Initialise the CAN network | |
- BYTE | Return |
Process
Process | |
Does the message processing. Call this often. | |
- UINT | TimeElapsed |
Time elapsed since last call, in mS. Can be zero for frequent calling. | |
- BYTE | Return |
Set_ECU_Name
Set_ECU_Name | |
Set the ECU Name | |
- STRING | Name |
- VOID | Return |
Set_Engine_Coolant_Temperature | |
-40 to 215 (deg C) | |
- FLOAT | Value |
Value range -40 to 215 deg C | |
- VOID | Return |
Set_Engine_Load
Set_Engine_Load | |
0 to 100 (%) | |
- FLOAT | Value |
Speed in RPM | |
- VOID | Return |
Set_Engine_Speed
Set_Engine_Speed | |
0 to 16,383.75 (rpm) | |
- FLOAT | Value |
Speed in RPM | |
- VOID | Return |
Set_MAF_Rate
Set_MAF_Rate | |
0 to 655.35 grams/sec | |
- FLOAT | Value |
MAF air flow rate in grams/sec | |
- VOID | Return |
Set_Throttle_Position | |
0 - 100 (%) | |
- FLOAT | Value |
Position value as a percentage (0 - 100%) | |
- VOID | Return |
Set_VIN
Set_VIN | |
Set the 17 character VIN | |
- STRING | VIN |
- VOID | Return |
Set_Vehicle_Speed
Set_Vehicle_Speed | |
0 - 255 (km/h) | |
- FLOAT | Value |
Speed in RPM | |
- VOID | Return |
