API Component.FindChild
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Finds a named object that is part of the component
Class hierarchy
Component
FindChild
HANDLE Current
Object to search children of
STRING ChildName
Name of the child to search for
HANDLE
A handle to the child of Current whose name matches ChildName
This call will search the components owned and in scope for the non-case sensitive ChildName.
This call is unnecessary if 'this' is passed as Current and ChildName is a literal string. In this case it is more efficient to use the constant variable which will point to the child component.
  • Add to a calculation icon:
    result = ::Component.FindChild(current, "childname")
