Component: MIAC (PIC) CAN Slave (MIAC: Addon Modules)
| Author | Matrix Ltd |
| Version | 1.4 (Release) |
| Category | MIAC: Addon Modules |
MIAC Slave for MIAC System. Requires Slave firmware program downloaded to a MIAC (PIC) to act as a CAN connected Slave device.
InputANALOG_10Bit
Returns the 10 bit value for the analogue input requested by parameter InputID
(Inputs 1 to 8)
- BYTE InputID
- The input to read from 1 to 8.
RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
- The relay to turn off. From 1 to 4.
PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
- <- STRING Str
- The string to send to the display.
GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
DisplayStart
Initialise the display ready for use
DisplayCommand
Sends the given command to the display
- BYTE Cmd
PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
- BYTE Char
- ASCII code of the character to print.
Prints the given number to the display starting at the current cursor position and moves the cursor position.
- INT n
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- Enter the number or variable to print to the LCD
- BOOL Format
- 0=Signed, 1=Unsigned
DisplayClear
Clears the display to white space
OutputOFF
Outputs a digital low state on the output requested by parameter TransID
(Outputs 1 to 4)
- BYTE TransID
- 1 to 4 (Outputs A to D)
RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
- The relay to turn on from 1 to 4.
DisplayCursor
Moves the display cursor to the given position.
If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
- BYTE x
- Position of the cursor in characters from left to right.
- BYTE y
- The line to move the cursor to.
OutputON
Outputs a digital high state on the output requested by parameter TransID
(Outputs 1 to 4)
- BYTE TransID
InputDIGITAL
Returns the digital state of the input requested by parameter InputID
(Inputs 1 to 8)
- BYTE InputID
- The input number from 1 to 8.
InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID
(Inputs 1 to 8)
- BYTE InputID
Simulation macro reference
EvClick
Module Type
This property is of type Fixed list of ints and can be referenced with the variable name MODULE_TYPE.
Module Address
This property is of type Fixed list of ints and can be referenced with the variable name ORDINAL.
