Component: MIAC (PIC) CAN Slave (MIAC: Addon Modules)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.4 |
Category | MIAC: Addon Modules |
MIAC (PIC) CAN Slave component
MIAC Slave for MIAC System. Requires Slave firmware program downloaded to a MIAC (PIC) to act as a CAN connected Slave device.
FREE
InputANALOG_10Bit | |
Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
- BYTE | InputID |
The input to read from 1 to 8. | |
- INT | Return |
RelayOFF | |
Turns off the requested relay given by parameter RelayID, values 1 to 4 | |
- BYTE | RelayID |
The relay to turn off. From 1 to 4. | |
- VOID | Return |
PrintString | |
Prints the given character string to the display at the current cursor position and moves the cursor position. | |
- STRING | Str |
The string to send to the display. | |
- VOID | Return |
GetKeypad | |
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255 | |
- BYTE | Return |
DisplayStart | |
Initialise the display ready for use | |
- VOID | Return |
DisplayCommand | |
Sends the given command to the display | |
- BYTE | Cmd |
- VOID | Return |
PrintASCII | |
Prints the given character to the display at the current cursor position and increments the cursor position. | |
- BYTE | Char |
ASCII code of the character to print. | |
- VOID | Return |
PrintNumber | |
Prints the given number to the display starting at the current cursor position and moves the cursor position. | |
- INT | n |
- VOID | Return |
MIAC_Module_SetData | |
- BYTE | Count |
- BYTE | D0 |
- BYTE | D1 |
- BYTE | D2 |
- BYTE | D3 |
- BYTE | D4 |
- BYTE | D5 |
- VOID | Return |
MIAC_Module_Init | |
- UINT | CAN_ID |
- VOID | Return |
MIAC_Module_GetData | |
- BYTE | Index |
- BYTE | Return |
MIAC_Module_Message | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- BYTE | Return |
DisplayClear | |
Clears the display to white space | |
- VOID | Return |
MIAC_Module_WR | |
- UINT | CAN_ID |
- UINT | CMD_ID |
[[File:]] - | Count |
[[File:]] - | Start |
[[File:]] - | More |
- VOID | Return |
MIAC_Module_PushData | |
- BYTE | Data |
- VOID | Return |
OutputOFF | |
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4) | |
- BYTE | TransID |
1 to 4 (Outputs A to D) | |
- VOID | Return |
RelayON | |
Turns on the requested relay given by parameter RelayID, values 1 to 4 | |
- BYTE | RelayID |
The relay to turn on from 1 to 4. | |
- VOID | Return |
OutputON | |
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4) | |
- BYTE | TransID |
- VOID | Return |
InputDIGITAL | |
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8) | |
- BYTE | InputID |
The input number from 1 to 8. | |
- BYTE | Return |
MIAC_Module_GetAck | |
- UINT | CAN_ID |
- UINT | CMD_ID |
- UINT | TimeOut |
- BYTE | Return |
InputANALOG | |
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
- BYTE | InputID |
- BYTE | Return |
Properties | |
Module Type | |
Module Address | |
Connections | |
Simulations |
