Component: CAN (CAL) (Misc)
| Version | 2.4 |
| Category | Misc |
CAN component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. Low level routines for controling the internal CAN peripheral.
COMMSA
| SetRxMask | |
| Generic function to set Identifier. CAN registers will be configured depending upon Std/Ext mode setting. | |
| mask | |
| id | |
| GetValue | |
| Get the Value of the Named property | |
| Name | |
| GetRxData | |
| Returns the data byte at index from the buffer specified | |
| buffer | |
| The index of the required buffer | |
| index | |
| The index of the required data byte in the buffer | |
| InitRXMask | |
| Initialization setting for RX Mask | |
| Mask | |
| Mask Number (0 or 1) | |
| Value | |
| SendBuffer | |
| Sends the contents of the buffer previously filled with Set_TX_... calls | |
| Buffer | |
| Send buffer: 0 to,2 | |
| InitRXFilter | |
| Initialization setting for RX Filter | |
| Filter | |
| Value | |
| GetRxDataCount | |
| Returns the number of valid data bytes in the buffer | |
| buffer | |
| Init | |
| Must be called at least once and after every Uninit call to enable the CAN instance | |
| SetValue | |
| Set the Value of the Named property | |
| Name | |
| Value | |
| SetRxFilter | |
| filter | |
| id | |
| SetTxIdent | |
| buffer | |
| id | |
| CheckRx | |
| Checks to see if any messages are available for 'Buffer' specified | |
| Buffer | |
| Send buffer: 0 to 1 | |
| InitRXConfig | |
| Initialization setting for RX Buffer Config | |
| Buffer | |
| Buffer Number (0 or 1) | |
| Value | |
| Config data byte | |
| Uninit | |
| Uninitialises the CAN, freeing its connections for general use | |
| GetList | |
| Get the Filter List of the Named Property | |
| Name | |
| GetRxIdent | |
| Generic function to get the received message Identifier. | |
| buffer | |
