Component: EEPROM (CAL) (Misc)
Revision as of 16:24, 7 January 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Misc
EEPROM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the EEPROM peripheral.
STORAGE
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Read
Read a byte from EEPROM Address
- UINT Address
Write
Write Data to EEPROM Address
- UINT Address
- UINT Data
Size
Type
Simulations
