Component: API OneWire Dummy (API Slave Devices)
Revision as of 17:44, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | MatrixTSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray;...")
Author MatrixTSL
Category API Slave Devices
API OneWire Dummy component
Please click here for the component source code: FC_Comp_Source_API_OneWire_Dummy.fcfx
OneWireBusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BYTE Channel
- BOOL Return
OneWireInitialise
Initialise the OneWire module ready for communications
- BYTE Channel
OneWireMatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE Channel
- BYTE FamilyCode
- BYTE SerialNumber
OneWireTransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Channel
- BYTE Data
OneWireGetIDByte
Returns a single byte of the 64-Bit lasered ROM code, 255 on error
- BYTE Channel
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
OneWireSkipROM
Performs a bus reset and the sends the SkipROM command byte
- BYTE Channel
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
OneWireGetDeviceCount
- BYTE Channel
