Component: API OneWire Dummy (API Slave Devices)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | API Slave Devices |
API OneWire Dummy component
Please click here to download the component source project: FC_Comp_Source_API_OneWire_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_OneWire_Dummy.fcfx
OneWireBusReset
OneWireGetDeviceCount
OneWireGetDeviceCount | |
Returns the number of devices found by the last ScanBus operation. | |
- BYTE | Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
- BYTE | Return |
OneWireGetIDByte
OneWireInitialise
OneWireInitialise | |
Initialise the OneWire module ready for communications | |
- BYTE | Channel |
- VOID | Return |
OneWireMatchROM
OneWireReceiveByte
OneWireReceiveByte | |
Receives a byte from the one wire bus a bit at a time | |
- BYTE | Channel |
- BYTE | Return |
OneWireScanBus
OneWireScanBus | |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
- BYTE | Channel |
- BYTE | Return |
OneWireSkipROM
OneWireSkipROM | |
Performs a bus reset and the sends the SkipROM command byte | |
- BYTE | Channel |
- VOID | Return |
OneWireTransmitByte
OneWireTransmitByte | |
Transmit a byte to the one wire bus a bit at a time | |
- BYTE | Channel |
- BYTE | Data |
- VOID | Return |
Properties |
