Component: UART Free (Peripheral CAL)
Revision as of 17:52, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.3 |- | width="20%" style="color:gray...")
Version 1.3
Category Peripheral CAL
UART Free component
A low level implementation giving direct access to the CAL
Please click here for the component source code: FC_Comp_Source_UART_Free.fcfx
Fc9-comp-macro.png UpdateBaud
Changes the UART Baud rate. 0 = 1200 / 1 = 2400 / 3 = 4800 / 3 = 9600 / 4 = 19200 / 5 = 38400 6 = 57600 / 7 = 115200
Fc9-u8-icon.png - BYTE new_baud
The new baud rate (0=1200, 7=115200)
Fc9-comp-macro.png GetValue
Get Value of Named property
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png Receive
Receive a Character
Fc9-u8-icon.png - BYTE Timeout
Period to wait for the character to be received
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png Send
Send the Character
Fc9-u16-icon.png - UINT Char
The Character to send
Fc9-comp-macro.png Init
Initialize the component with the specified properties
Fc9-comp-macro.png Delay
Software UART Bit Delay
Fc9-comp-macro.png SetValue
set Value of Named property
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png GetList
Gets Named property List
Fc9-type-16-icon.png Channel
UART Channel selector
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Data Bits
Number of data bits
Fc9-type-16-icon.png Return
Return data width from Receive macro
Fc9-type-16-icon.png Echo
Echo selection
Fc9-type-16-icon.png Interrupt
Interrupt mode enable or disable
Fc9-type-16-icon.png Flow Control
Flow Control (Handshake) enable or disable
Fc9-conn-icon.png Simulation
