Dashboard Panel
Revision as of 09:10, 15 May 2013 by JonnyW (talk | contribs) (Partial mod to stylize article)
File:Dash panel.jpg
The Dashboard Panel
The Dashboard Panel provides another framework on which to load Flowcode components.
Overview
File:Gen opt icon.jpg
The Dashboard Panel is opened by selecting it in the View menu. When it opens, you see a colored workspace.
The color is set in the General Options
File:Three d icon.jpg
Unlike the System Panel, the Dashboard Panel gives only a top-down view of the components, though they can be made more lifelike by clicking on the ‘3D view’ icon.
Electronic devices, located in the Components toolbox, can be added to the Dashboard Panel. You usually place buttons and other controls on it to ensure that they are always available, even when they are out of sight on the System Panel component because of object or camera rotation.
When the Dashboard Panel opens, you see a background work area, with a Shapes toolbar running vertically down the left-hand side, and a Controls toolbar running horizontally across the top.
  • by holding down the Shift key and then clicking on a number of items, one after the other;
  • by left-clicking the mouse button and dragging over the items.
File:Group icon.jpg
They can then be grouped:
  • by clicking on the ‘group’ icon.
  • by selecting the ‘Group’ option from the ‘Selection’ option which appears when you click the right-hand mouse button.
In this way, complex structures can be assembled from a number of parts. To ungroup, select the object and then click on the same icon.
The controls
File:D shapes toolbar.jpg
Shapes toolbar
At the top is a color selector, which configures the color of any shape added to the work area. By clicking on the down-arrow, one of a wide range of colors can be selected.
Below it is the text icon. This can be used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, it is initially displayed as “Please change caption.” You can edit the text displayed using the bottom ‘Text’ control on the Properties Panel.
The next icon on this toolbar allows you to add a textbox. This adds a two-dimensional array of alphanumeric characters. As before, these can be edited using the ‘Text’ control on the Properties Panel. The ‘Color’ and the ‘Background’ properties allow you to change the color of the text in the textbox, and the background to that text. Other controls allow you to select the character font and size, and the horizontal and vertical alignment of the text within the textbox.
The next four icons allow you to add various shapes - a circle, a rectangle, a rounded rectangle and a line, to the work area. Each takes the colour chosen in the color selector at the top. Each can be configured using the Properties Panel, to determine the position, size and rotation of the shape, for example.
Controls toolbar
The first four controls operate on the size, position and rotation of the component. These decide how the objects on the panel to be manipulated and edited. Only one of these can be selected at a time.
File:Comp con.jpg
Component controls
File:Pan icon.jpg The left-hand end control allows you to move the selected object around the work area.
File:Stretch icon.jpg Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink ‘handles’ appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Resize icon.jpg The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue ‘handles’ appear on the object. Any of these can be ‘grabbed’ and moved to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
File:Comp rotate icon.jpg The fourth control allows you to rotate an object. After selecting it and clicking on this control, a number of yellow ‘handles’ appear on the object. These allow the object to be rotated around different axes.
File:Collis icon.jpg
The next control (show icon) determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other.
The next one allows a pseudo three-dimensional effect to make the objects look more life-like.
File:Spann opt icon.jpg
The first (show icon) allows you to lock movement of objects:
  • to the grid,
  • to other objects,
  • to the table-top.
The second is used to:
  • set the number of views, allowing, for example, plan and elevation views of a component;
  • set the resolution, ‘level of detail’, of the display.
File:Zoom icon.jpg
There is also a zoom facility, operated by pressing the Ctrl key and moving the cursor over the viewpoint icon. Clicking the mouse button and dragging downwards causes the view to zoom out. Dragging upwards causes the view to zoom in.
Exercises
