| Author
Matrix TSL
| Version
2.0
| Category
Misc
ADC component
CAL - Code Abstraction Layer A low level implementation giving direct access to the analogue to digital converter peripheral.
Please click here to download the component source project: FC_Comp_Source_ADC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ADC.fcfx
GetValue
| Gets the Name property value
- STRING
Name
| The name of the property
- STRING
Disable
| Disables the current ADC channel Call this once sampling is complete
Enable
| Enables sampling of the ADC channel This is called every time a new ADC channel needs configuring to ADC mode [u]Only one ADC channel may be enabled at any time[/u] When sampling is complete, call Disable() to restore the pin
- BYTE
| A value >= 0 specifying the ADC channel
- BYTE
Conv_Speed
| Chip-specific rate of change read from the FCD <ADC.ConfSpeed>
- BYTE
Vref
| 0 to disable Vref mode, else 1
- BYTE
T_Charge
| Aquisition time to wait in micro seconds
Sample
| Blocking call to read a sample on the currently enabled channel
- BYTE
Sample_Mode
| True to enable full-width sample (10 or 12 bits), else false for 8 bit
- UINT
SetValue
| Sets the Value for the named property
- STRING
Name
| Name of property to update
- STRING
Value
| The new value for the property
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
| ADC Channel number
Vref Option
| selects the reference voltage option
Vref+ (x10mV)
| sets the value of the reference voltage (used for conversion calculations)
Acq Time
| ADC Aquisition time
Use FRC clock
| Uses the internal fixed RC clock to perform ADC conversions. In most cases it is better to switch this off and use the conversion speed to ensure sampling is consistent.
Conv Speed
| Conversion speed option
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
| ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
| ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
| ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
| ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
GetValue
- STRING
Name
- STRING
Disable
Enable
- BYTE
- BYTE
Conv_Speed
- BYTE
Vref
- BYTE
T_Charge
Sample
- BYTE
Sample_Mode
- UINT
SetValue
- STRING
Name
- STRING
Value
GetList
- STRING
Name
- STRING
Peripheral
Channel ADC Pin
| ADC Channel number
Vref Option
Vref+ (x10mV)
Acq Time
| ADC Aquisition time
Use FRC clock
Conv Speed
Type
Bits
Custom Pins
Has DMA
Use DMA
DMA Trigger
Has Scanning
Use Scanning
