Author
Matrix Ltd
Version
1.3
Category
Peripheral CAL
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
Slave_Uninit
Uninitialise the Slave
GetValue
Get the Named property value.
- STRING
Name
- STRING
Master_Stop
Output a Master Stop
Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE
Address
7 Bit Address of this device (Bit 0 is ignored)
- BYTE
Mask
Bit mask used to compare addresses
Master_Uninit
Uninitialise the Master
Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
- BYTE
GetConsoleHandle
Obtains the CAL console handle
- HANDLE
Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE
Data
- BYTE
Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE
Last
Sends Ack if 0, else Nak
- BYTE
SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING
Name
- STRING
Value
port value as string
Master_Init
Initialise the Master
Master_Start
Output a Master Start sequence
Master_TxByte
Send a data byte
- BYTE
Data
- BYTE
Master_Restart
Output a Master Restart sequence
Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE
Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
- BYTE
GetList
returns Named property List as filter string
- STRING
Name
- STRING
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Stop Delay
Slave_Uninit
GetValue
- STRING
Name
- STRING
Master_Stop
Slave_Init
- BYTE
Address
- BYTE
Mask
Master_Uninit
Slave_Status
- BYTE
GetConsoleHandle
- HANDLE
Slave_TxByte
- BYTE
Data
- BYTE
Slave_RxByte
- BYTE
Last
- BYTE
SetValue
- STRING
Name
- STRING
Value
Master_Init
Master_Start
Master_TxByte
Send a data byte
- BYTE
Data
- BYTE
Master_Restart
Master_RxByte
- BYTE
Last
- BYTE
GetList
- STRING
Name
- STRING
Channel selection
SDA
SCL
Baud Select
Slew Rate Control
SMBus Inputs
Stop Delay
Slave_Uninit
GetValue
- STRING
Name
- STRING
Master_Stop
Slave_Init
- BYTE
Address
- BYTE
Mask
Master_Uninit
Slave_Status
- BYTE
GetConsoleHandle
- HANDLE
Slave_TxByte
- BYTE
Data
- BYTE
Slave_RxByte
- BYTE
Last
- BYTE
SetValue
- STRING
Name
- STRING
Value
Master_Init
Master_Start
Master_TxByte
Send a data byte
- BYTE
Data
- BYTE
Master_Restart
Master_RxByte
- BYTE
Last
- BYTE
GetList
- STRING
Name
- STRING
Channel selection
SDA
SCL
Baud Select
Slew Rate Control
SMBus Inputs
Stop Delay
Slave_Uninit
GetValue
- STRING
Name
- STRING
Master_Stop
Slave_Init
- BYTE
Address
- BYTE
Mask
Master_Uninit
Slave_Status
- BYTE
GetConsoleHandle
- HANDLE
Slave_TxByte
- BYTE
Data
- BYTE
Slave_RxByte
- BYTE
Last
- BYTE
SetValue
- STRING
Name
- STRING
Value
Master_Init
Master_Start
Master_TxByte
Send a data byte
- BYTE
Data
- BYTE
Master_Restart
Master_RxByte
- BYTE
Last
- BYTE
GetList
- STRING
Name
- STRING
Channel selection
SDA
SCL
Baud Select
Slew Rate Control
SMBus Inputs
Stop Delay
