Component: UART Free (RS232) (Misc)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
UART_Free (RS232) component
Low level routines for controlling or interacting with a standard asyncronous serial interface. On a microcontroller the interface will be the onboard UART which will need voltage level shifting using a max2323 to become RS232 compatible. See the EB015 RS232 E-block for details.
Please click here to download the component source project: FC_Comp_Source_RS232_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RS232_Free.fcfx
Overview
The RS232 component is in fact nothing more than a TTL level asynchronous serial communications bus which basically means that there is no clock signal. Instead the data is sent out at a precise data rate specified by the Baud which is represented in bits per second. Both devices need to be set to the same rate to allow communications to work correctly.
There are two signals which make up the asynchronous serial connection: RX and TX. The receive RX signal is used for incoming data and the transmit TX signal is used for outgoing data. When connecting two devices together it is important to connect the TX of one device to the RX of the other and visa versa. When inactive the bus defaults to having the TX signal held in the high state. Each data byte sent then starts with a low signal for 1 period of the baud rate to signify that data is to follow.
Each RS232 transaction consists of a start bit (low) for a single clock cycle followed by data made up of 7/8/9 clock cycles followed by a stop bit (high) for a single clock cycle.
TTL
By default the RS232 component will provide TTL asynchronous serial data which is best suited for a single device to single device data connection on the same circuit board. An example might be a GSM modem or GPS module. The TTL signals are normally at VCC when the bus is idle and toggles between VCC and Ground when sending data.
RS232
By adding a driver chip such as a MAX2323 the TTL signals can be upgraded to RS232 which is best suited for single device to single device mid range off board communications. The RS232 signals replace the voltages VCC with +12V and GND with -12V to allow for better noise rejection in noisy environments.
RS485
By adding a driver chip such as a MAX3078 the TTL signals can be upgraded to RS485 which is best suited for master to multiple slave type mid range off board communications.
Auto Baud
Some devices feature an auto baud functionality and is commonly triggered by sending a known data byte to the device before any other data is sent allowing the correct baud to be worked out.
Importing from v5
The RS232 component from Flowcode v6 has a new Initialise macro which will need to be added to your program before any other calls to the component are made.
Transmit
This example transmits a string "Hello World". RS232_Example1 The Console window shows the data as it is sent and received.
Receive
This example receives a character and outputs it to the LCD, an injector has been added to allow you to type data into the console. RS232_Example2 The Console window has tabs for the human interface data injector allowing you to type in data that will be received by the component.
Again the RS232 console tabs reflect the data as it is sent and received.
LCD showing received data.
Transmit and Receive
This example echoes back any data that is received allowing a nice sanity check when connecting an embedded device to a PC or other source of communications. RS232_Example3 Again the RS232 console tabs reflect the data as it is sent and received.
UART Bridge
This example allows a microcontroller with two UART peripherals to receive data one one UART and transmit on the other and visa versa in a reliable manner using interrupts. Note that this method will only work with hardware UART channels. A software UART could be done in a similar way using a falling edge type interrupt on the UART RX pin to trigger the receive function. RS232_Example4
COM Port
The COM port property allows you to attach the RS232 component to a COM port on your PC during simulation allowing real world hardware such as RS232, Bluetooth, GPS to work with the simulation.
Injector
The Injector property allows you to select an injector component on the panel for use in the simulation. The human interface injector can be used to inject typed in data via the console window and can be seen in examples 2 and 3 above.
There are other pre-made injectors to allow you to do various aspects from simulating a generic AT terminal to simulating a specific remote device.
SendString
Sends out a string of bytes from the UART interface.
- STRING Data
SendNumber
Sends out a number as an ASCII String from the UART interface.
[[File:]] - Number
SendChar
Sends out a single packet from the UART interface.
- INT Char
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE NewBaud
ReceiveString
Attempts to receive a string of bytes from the UART interface.
- BYTE Timeout
- UINT NumBytes
The number of bytes to try and receive, ideally your string variable should have at least 1 more byte to store the null termination byte
- STRING Return
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveChar
Attempts to receive a single packet from the UART interface.
- INT Timeout
Time to wait for valid data before returning, 0=Dont wait, 255=Wait forever.
- INT Return
Comms Settings
Baud Options
Data Bits
Number of data bits
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
Automatically echoes back any received data when enabled by re-transmitting the received byte.
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
TX Alt Pin
Allows the TX pin to be allocated to an alternate I/O pin.
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
RX Alt Pin
Allows the RX pin to be allocated to an alternate I/O pin.
Use Flow Control
RTS
Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
CTS
Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Textual label shown on the component I/O flasher
Console Columns
Data Source
SendString
- STRING Data
SendNumber
[[File:]] - Number
SendChar
- INT Char
ChangeHWBaud
- BYTE NewBaud
ReceiveString
- BYTE Timeout
- UINT NumBytes
- STRING Return
ReceiveChar
- INT Timeout
- INT Return
Comms Settings
Baud Options
Data Bits
Number of data bits
Echo
Use TX
TX
TX Alt Pin
Use RX
RX
RX Alt Pin
Use Flow Control
RTS
CTS
Console Columns
Data Source
SendString
- STRING Data
SendNumber
[[File:]] - Number
SendChar
- INT Char
ChangeHWBaud
- BYTE NewBaud
ReceiveString
- BYTE Timeout
- UINT NumBytes
- STRING Return
ReceiveChar
- INT Timeout
- INT Return
Comms Settings
Baud Options
Data Bits
Number of data bits
Echo
Use TX
TX
TX Alt Pin
Use RX
RX
RX Alt Pin
Use Flow Control
RTS
CTS
Console Columns
Data Source
SendString
- STRING Data
SendNumber
[[File:]] - Number
SendChar
- INT Char
ChangeHWBaud
- BYTE NewBaud
ReceiveString
- BYTE Timeout
- UINT NumBytes
- STRING Return
ReceiveChar
- INT Timeout
- INT Return
Comms Settings
Baud Options
Data Bits
Number of data bits
Echo
Use TX
TX
TX Alt Pin
Use RX
RX
RX Alt Pin
Use Flow Control
RTS
CTS
Console Columns
Data Source
