Component: PWM Free (Peripheral CAL)
Revision as of 12:02, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Peripheral CAL
PWM Free component
A low level implementation giving direct access to the CAL
Please click here to download the component source project: FC_Comp_Source_temp/PWM_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/PWM_Free.fcfx
ChangePeriod
Fc9-comp-macro.png ChangePeriod
Change the Period (and prescaler) for this PWM Channel
Fc9-u16-icon.png - UINT period
period value PIC/AVR: 0-255 16-bit PIC: 0-65535
Fc9-u16-icon.png - UINT prescaler
prescaler 1,4,16,64
Disable
Fc9-comp-macro.png Disable
Disable this PWM Channel
Enable
Fc9-comp-macro.png Enable
Enable this PWM Channel
GetList
Fc9-comp-macro.png GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
Fc9-string-icon.png - STRING Name
GetValue
Fc9-comp-macro.png GetValue
Returns Named property Value
SetDuty10Bit
Fc9-comp-macro.png SetDuty10Bit
Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535
Fc9-u16-icon.png - UINT duty
Duty value 0 - 1023
SetDuty8Bit
Fc9-comp-macro.png SetDuty8Bit
Set the Duty cycle (0-255) for this PWM Channel
Fc9-u8-icon.png - BYTE duty
duty value 0 - 255
SetValue
Fc9-comp-macro.png SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
Fc9-string-icon.png - STRING Value
Fc9-type-16-icon.png Channel
PWM Channel selector
Fc9-type-16-icon.png Alt Pin Enable
Alternative Pin Enable (if available on target device)
Fc9-type-5-icon.png Port
Fc9-type-14-icon.png Period Register
PWM Period Register value
Fc9-type-16-icon.png Prescaler Divide
Prescaler Divider value
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-14-icon.png Clock Speed
Fc9-type-15-icon.png Period (uS)
Fc9-type-15-icon.png Frequency (KHz)
Fc9-type-14-icon.png Master Divider
