Component: I2C Free (Peripheral CAL)
Revision as of 13:10, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Peripheral CAL
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
GetConsoleHandle
Obtains the CAL console handle
GetList
Fc9-comp-macro.png GetList
returns Named property List as filter string
Fc9-string-icon.png - STRING Name
GetValue
Fc9-comp-macro.png GetValue
Get the Named property value.
Master_Init
Fc9-comp-macro.png Master_Init
Initialise the Master
Master_Restart
Fc9-comp-macro.png Master_Restart
Output a Master Restart sequence
Master_RxByte
Fc9-comp-macro.png Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
Fc9-u8-icon.png - BYTE Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
Master_Start
Fc9-comp-macro.png Master_Start
Output a Master Start sequence
Master_Stop
Fc9-comp-macro.png Master_Stop
Output a Master Stop
Master_TxByte
Fc9-comp-macro.png Master_TxByte
Send a data byte
Fc9-u8-icon.png - BYTE Data
Master_Uninit
Fc9-comp-macro.png Master_Uninit
Uninitialise the Master
SetValue
Fc9-comp-macro.png SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
Fc9-string-icon.png - STRING Value
port value as string
Slave_Init
Fc9-comp-macro.png Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
7 Bit Address of this device (Bit 0 is ignored)
Fc9-u8-icon.png - BYTE Mask
Bit mask used to compare addresses
Slave_RxByte
Fc9-comp-macro.png Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
Sends Ack if 0, else Nak
Slave_Status
Fc9-comp-macro.png Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Slave_TxByte
Fc9-comp-macro.png Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
Slave_Uninit
Fc9-comp-macro.png Slave_Uninit
Uninitialise the Slave
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png Slew Rate Control
Slew Rate Control Enabled or Disabled
Fc9-type-16-icon.png SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Fc9-conn-icon.png Simulation
