Component: EEPROM (CAL) (Misc)
Revision as of 10:23, 24 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Misc
EEPROM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the EEPROM peripheral.
Please click here to download the component source project: FC_Comp_Source_EEPROM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM.fcfx
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Read
Read a byte from EEPROM Address
- UINT Address
Write
Write Data to EEPROM Address
- UINT Address
- UINT Data
Size
Type
Simulations
GetValue
GetValue
- STRING Name
- STRING Return
Read
Read
- UINT Address
Write
Write
- UINT Address
- UINT Data
Size
Type
