DSP
Revision as of 12:23, 17 October 2023 by BenR (talk | contribs) (→DSP Components)
What is DSP
  • Audio effects e.g. Echo, Reverb, Guitar Distortion, etc
  • Signal Filtering
  • Frequency Spectrum Analysis
  • Baby Monitors
  • Radio Telescopes
  • Control e.g. Speed, Position, Temperature, Height, Level, Angle, etc
  • Modern Digital Communications
DSP components with an arrow facing away from the component represent a memory block or buffer that can be accessed by one or more other DSP components. The number of values that can be stored and the type of values that can be stored are available via the component properties.
DSP components with an arrow facing towards the component represent a reference to the memory block created by another DSP component. The link is controlled via the component properties.
Once DSP components are linked together a line is drawn between the components. The colour of the line indicates the type of data that is being passed.
DSP Inputs
Input ADC Inputs from an ADC enabled input pin
Input CSV Inputs data from a file
Input Digital Inputs generic digital data
Input Digital Pin Inputs from a digital input pin
Waveform Generator Generates cyclic or randomised waveform data
DSP Outputs
Level Monitors data statistics like peaks and troughs
Output CSV Outputs to a file
Output DAC Outputs to a DAC enabled output pin
Output Digital Outputs generic digital data
Output Digital Pin Outputs to a digital output pin
Output PWM Outputs to a PWM enabled output pin
DSP Operators
Adder Adds together two or more DSP signals
Averager Takes an average of two or more DSP signals
Deinterlace Breaks apart a single interlaced DSP signal into sub signals
Delay Adds a fixed or variable delay in the DSP signal
Fast Fourier Transform (FFT) Converts time based DSP signal data into Frequency based
Filter Provides digital filtering on a DSP signal
Interlace Combines multiple DSP signals into a single DSP signal
Kalman Filter Provides predictive digital filtering on a DSP signal
Math Mathematical operations with two DSP signals (+,-,/,* etc)
Median Provides median filtering on a DSP signal to get rid of spurious data samples
Multiplex Allows a number of DSP signals to be selected and switched between
Offset Adds a fixed or variable offset to a DSP signal
On/Off Control Provides simple on/off closed loop control
PID Control Provides P/PI/PID closed loop control
Rectifier Allows a DSP signal to be flipped below a certain threshold
Scale Applies a scaler to a DSP signal
Simulated Control Load Simulates an active load such as a heater or motor to allow simulation of closed loop systems
Component Macros
A typical DSP system will use a timer interrupt macro to maintain a steady rate on which everything happens. The timer interrupt will do things like any analogue sampling and may also call the DSP component functions in order. Based on this methodology we have created two variants of most of the DSP component macros in the form of Function and FunctionArray. These allow two different ways of working with the DSP component. These methods can be mixed and matched as necessary to allow your program to run at the optimum speed and throughput.
Single
The Function type macros allow a single value in the DSP buffer to be processed. Behind the scenes this performs the hardware macro functionality on the next buffer value.
The tick based functions are designed to operate inside the interrupt function at sample rate. This allows your DSP code to utilize more of the system runtime but means you have less time for other functions such as refreshing a display. Because you are only processing a single value in a buffer rather then an entire buffer the function code is much shorter. This also has a second impact that there is a minimal delay in data being held in the buffer before being processed. The location inside the buffer is automatically tracked for you by the master buffer index.
Array
The Array type macros allow the entire DSP buffer to be processed at once. Behind the scenes this involves a loop and we cycle through all of the values in the buffer performing the macro function. Some components such as the DSP FFT only have the Array version of the macro as the FFT calculations can only work with a buffer full of data.
The standard array based functions are designed to process a complete buffer in one operation. Care should be taken that the processing time is no longer then a single interrupt period.
This method gives you free time between interrupts where other functions can be performed such as updating the GUI on a display. The longer the buffers, the more time you get between having to process the trigger code but the downside is that the trigger code will take more time to process.
Combining Single and Array Calls
The single style approach is similar to using the trigger style approach with a buffer size of one so really the design of the system is entirely up to what you feel most comfortable with and what best suits your application.
