Component: GLCD (ST7920) (Graphical Monochrome)
Revision as of 10:12, 25 June 2024 by Wiki bot (talk | contribs)
Version 1.5
Category Graphical Monochrome
GLCD (ST7920) component
Graphical display component designed to work with the ST7920 type monochrome displays. Transfers data using an 8-bit/4-bit/SPI digital data bus.
Version information
11, 1.4, 03-05-24, BR, Added SPI data mode to the component to work with serial displays
12, 1.4, 20-06-24, BR, Fixed a bug where read SPI pixel data was being repacked incorrectly
13, 1.5, 25-06-24, BR, Added an option to allow the pixel data to be buffer locally
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
Write_Command
Write_Command
- BYTE Command
Write_Data
Write_Data
- BYTE data
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Mode
Local Buffer
The display needs pixels to be assigned in blocks of 8 so for the display to function correctly we need to be able to know the value of pixels on the display to be able to draw without corruption. No - Use the display itself as a pixel buffer Yes - Use the local RAM as a pixel buffer
Reset
Reset pin
Parrallel Pins
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
RS
Enable
Enable pin used to clock data into the display
RW
Read Write pin to set the display data mode
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7920.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7920.fcfx
