API Panel.Position.RotateZ
Revision as of 14:08, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
RotateZ
Rotates the object around the Z axis
- HANDLE Handle
- HANDLE PivotHandle
An optional position to treat as the origin to rotate around
- FLOAT Degrees
Number of degrees to rotate by
- NONE Return
The rotation call allows an object to be rotated around any point in the target objects local Z axis. This has the effect of altering the roll of the object - in terms of an aeroplane this makes the plane spin around.
The handle must be a valid handle to a component or position, or a quoted (string) name of an object that can be selected on the panel.
The image to the right shows a cube with it's axis positions identified.
Calling the simulation api Panel.Position.RotateZ(MyCube,MyCube,1) will rotate the object in one-degree steps along it's Z-axis as shown by the blue rotation arc. To rotate the cube in a counter direction simply specify a negative number for the degrees parameter.
The screenshot from Flowcode v6 below shows a cuboid with it's internal axis shown (blue is the Z-axis line), and also a circle that cuts right through the cuboid's Z-axis (see example section below for links to the file) When the program runs the cuboid rotates along it's Z axis.
See also
Object Rotation
Local and World Space
  • Add to a calculation icon:
    ::Panel.Position.RotateZ(handle, pivothandle, degrees)
Flowcode example file
Download SIMAPI_Panel_Position_RotateZ_v1 and open it in Flowcode v6.
The sample file SIMAPI Panel Position RotateXYZ rotates a grouped object around its X, Y, and Z axis.
