Component: SysBlocks (E-blocks 2)
Category E-blocks 2
SysBlocks component
Please click here for a Sysblocks getting started guide.
More information on the Sysblocks component can be found here.
Here is an example of Sysblocks in action, here we are generating the fourier series.
Sysblocks Fourier Series example
Initialise components
LCDClear
LCDClear
LCDWriteString
LCDWriteString
- BYTE X
- BYTE Y
- STRING Data
ReadEncoderCounter
ReadEncoderCounter
Reads the current dial counter This is a counter from -32768 to 32767
- BYTE Channel
Range: 0-1
- INT Return
ReadSwitch
ReadSwitch
Samples one of the digital switches
- BYTE Channel
Range: 0-2
- BOOL Return
ReadSwitches
ReadSwitches
Samples all of the digital switches and returns as a three bit value.
ResetEncoderCounter
ResetEncoderCounter
Resets the encoder dial counter to zero
- BYTE Channel
Range: 0-1
SetDigitalPotWiper
SetDigitalPotWiper
Sets the value of one of the digital potentiometers.
- BYTE Channel
Range: 0-5
- UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
UsbGetByte
UsbGetByte
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty.
UsbGetNumberBytes
UsbGetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
UsbLookForValue
UsbLookForValue
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
- STRING Value
Value to look for, can be a string or byte array,
- BYTE NumChars
The number of characters you wish to try and match
- BYTE RemoveContent
0=Leave data alone, 1=Remove data from buffer
- BYTE ResetFind
0=Continue the find from the last operation, 1=Start again
UsbSendString
UsbSendString
Sends a string to the USB
- STRING Data
String to send
WriteLED
WriteLED
Writes to one of the LEDs as a digital output
- BYTE Channel
Range: 0-2
- BOOL Value
0=Off, 1=On
WriteLEDs
WriteLEDs
Writes to all of the LEDs as digital outputs
- BYTE Values
Range: 0 (All Off) - 7 (All On)
WriteVU
WriteVU
Writes to one of the 8-bit VU meters
- BYTE Channel
0=VU_A, 1=VU_B
- BYTE Value
Range: 0-255
WriteVUBargraph
WriteVUBargraph
Outputs a bargraph to the VU allowing for level visualiusation.
- BYTE Channel
0 = VU_A, 1=VU_B
- BYTE Value
Range: 0 - 8
==Component Source Code==
Please click here to download the component source project: FC_Comp_Source_SysBlocks.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SysBlocks.fcfx
