Component: GLCD (SSD1327) I2C (SSD1327) (Graphical Monochrome)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.9
Category Graphical Monochrome
GLCD (SSD1327) I2C component
Graphical display component based on the I2C version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Version information
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
ControlDisplay
ControlDisplay
Allows the display to be switched on and off
- BYTE Control
0=Off, 1=On
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
InvertDisplay
InvertDisplay
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
Refresh
Refresh
Refreshes the entire display by sending the contents of the local RAM to the display at high speed
SendCommand
SendCommand
- BYTE Command
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
SetShadeIntensity
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE Shade
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Flip
Determines if the display is flipped or not
Auto Draw
Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
I2C Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Fonts
Font Count
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
Component Label Scale
Physical Orientation
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
