Component: I2C Free (Peripheral CAL)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.3
Category Peripheral CAL
I2C Free component
Chip Abstraction Layer for Two Wire I2C Communications
Please click here to download the component source project: FC_Comp_Source_I2C_Free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2C_Free.fcfx
GetConsoleHandle
GetConsoleHandle
Obtains the CAL console handle
- HANDLE Return
GetList
GetList
returns Named property List as filter string
- STRING Name
- STRING Return
GetValue
GetValue
Get the Named property value.
- STRING Name
- STRING Return
Master_Init
Master_Init
Initialise the Master
Master_Restart
Master_Restart
Output a Master Restart sequence
Master_RxByte
Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
Master_Start
Master_Start
Output a Master Start sequence
Master_Stop
Master_Stop
Output a Master Stop
Master_TxByte
Master_TxByte
Send a data byte
- BYTE Data
Master_Uninit
Master_Uninit
Uninitialise the Master
SetValue
SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING Name
- STRING Value
port value as string
Slave_Init
Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE Address
7 Bit Address of this device (Bit 0 is ignored)
- BYTE Mask
Bit mask used to compare addresses
Slave_RxByte
Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE Last
Sends Ack if 0, else Nak
Slave_Status
Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
Slave_TxByte
Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE Data
Slave_Uninit
Slave_Uninit
Uninitialise the Slave
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Stop Delay
