Component: EEPROM (CAL) (Misc)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 2.0
Category Misc
EEPROM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the EEPROM peripheral.
Please click here to download the component source project: FC_Comp_Source_EEPROM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EEPROM.fcfx
GetValue
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Read
Read
Read a byte from EEPROM Address
- UINT Address
Write
Write
Write Data to EEPROM Address
- UINT Address
- UINT Data
Size
Type
