| Author
Matrix Ltd
| Version
1.6
| Category
Graphical Monochrome
GLCD (SSD1306) Buffered component
Graphical display component based on the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
ControlContrast
ControlContrast
| Sets the display contrast from 0 to 255.
- BYTE
Contrast
| Range 0 - 255, Default 207
ControlDisplay
ControlDisplay
| Allows the display to be switched on and off
- BYTE
Control
| 0=Off, 1=On
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
| Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT
X0
| Start X coordinate
- UINT
Y0
| Start Y coordinate
- UINT
CX
| Control point X coordinate
- UINT
CY
| Control point Y coordinate
- UINT
X2
| End X coordinate
- UINT
Y2
| End Y coordinate
- UINT
Resolution
| Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
InvertDisplay
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SendCommand
SendCommand
- BYTE
Command
SetBackgroundColour
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
Dimensions
Pixel Width
Pixel Height
Interlaced
| Determines if the display is interlaced in the Y axis or not
Offset X
Offset Y
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
| Chip select pin connection
Reg Select (RS)
Data (SD)
| LED backlight strobe pin connection
Serial Clock (SCK)
| Reset pin connection
Reset (RST)
| Instruction / Command pin connection
Fonts
Font Count
Font 0
Font
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Space Width
Simulation Mode
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1306_buffered.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1306_buffered.fcfx
