Exercise - System Panel - Adding Objects
This exercise starts the process of building the display panel for a car. It sets up the System Panel, with a warning LED. Although specific settings are given, you should play around with alternatives to see the effect.
New flowchart
- Open a new Flowcode flowchart, using the default microcontroller.
- Make sure that the System Panel is visible. If necessary, click on View and then on the check-box next to 'System Panel'.
General options
- Click on the 'General options' tab File:Panel Icon GeneralOpts.jpg
- Make the following changes:
- Move the 'Level of detail' slider fully to the right (to '10').
- Select 'Table top' shadow mode.
- Choose a 'Background' style of 'Solid color' and set the background color to dark blue, (Red=0, Green=0, Blue=128 on the 'Custom' tab.)
- Set the 'Table top' size to '20'.
- Choose a 'Table top' style of 'Solid color' and set its color to light blue, (Red=0, Green=70, Blue=255 on the 'Custom' tab.)
Grid and snap options
- Click on the 'Grid and Snap options' tab File:Panel Icon Tools.jpg
- Set it to snap to the 'Table top', by clicking on the check-box next to the 'Table top' label.
- Leave the 'Show' gridlines box unchecked.
Add the LED
- Click on the 'Outputs' toolbox and locate the 'Single LED'.
- Click on the down-arrow next to it and then on 'Add to system panel'.
- Right click anywhere on the System Panel and select the 'Zoom to 100%' option.
- The System Panel should now resemble the one shown below.
Change the LED properties
- Click on the LED to select it.
- In the Panel Properties, two properties appear for the LED - 'color' and 'pin'.
- The 'color' property is set as red (0x0000FF). Click on this value, and change it to orange (0x0080FF).
- You may see very little change in the appearance of the LED, as currently it is turned off.
- The 'pin' property determines which pin of the microcontroller the LED is connected to.
- Currently, this is $PORTA,0 (pin 0 of PORTA). Click on the label. A pinout of the microcontroller appears.
- Click on bit 1 (RA1/AN1) to change this connection.
- The Panel Properties also gives information about the size and position of the LED.
- By default, size is shown in terms of 'Scale'.
- Hover the cursor over the folder icon next to the 'Scale' label, and then click on the down-arrow that appears.
- Select 'World size'.
- Click on the 'Width' setting, (which may be shortened to 'Wi...'). Change it to 10mm.
- In similar fashion, change the 'Height' ('He...') to 10mm and the 'Depth' ('De...') to 5mm.
Zoom in
- As a result, the LED now looks very small on the System Panel.
- You can zoom in to make it look larger. To do this:
- Hold down the control 'Ctrl' key on the keyboard. The 'zoom' icon appears. File:Panel Icon Zoom.jpg
- Move the cursor over this icon. Now when you move the cursor up the screen, the view zooms in, and when you move it down, it zooms out.
- Adjust the zoom so that the 'Table top' fills most of the System Panel, making the LED more visible.
Switch on
- Click and drag an 'Output' icon to your flowchart.
- Double-click on it and change the 'Variable or value' setting from '0' to '255'.
- This sends a logic 1 signal to all pins of PORT A.
- The flowchart resembles the one below:
- Run the simulation, by clicking on the 'Run' icon shown opposite.
- The LED will 'turn on'.
- Double-click on the 'Output' icon again, and change the value to '0'.
- Now when you simulate the flowchart, the LED will turn off.
- Save the flowchart as "System_Panel_Add_LED"
What next
The next stage is to mount the LED on the instrument panel. This is covered in the exercise controlling shapes
