Exercise - System Panel - Controlling Shapes
Revision as of 10:12, 1 June 2013 by JohnVerrill (talk | contribs)
The following assumes that you have added a single LED to the System Panel, as described in Exercise - System Panel - Adding Objects.
The aim of this exercise is to mount the LED on the car's instrument panel, and to control the viewpoint of the resulting component.
Open the LED flowchart
  • Open the flowchart "System_Panel_Add_LED" which you created in Exercise - System Panel - Adding Objects.
  • Check that the Panel Properties is displaying sizes as 'World size'.
  • Move the LED into the top right-hand corner by clicking on the 'Move with the mouse' icon.
Add the instrument panel
  • Click and drag a cylinder from the vertical toolbar onto the System Panel.
  • Click on it to select it. You will see five properties listed on the Panel Properties,
'Shape', 'Color', 'Outline', 'Thickness' and 'Image'.
  • The default 'color' property is red (0x0000C0). Click on its value, and change the color to black (0x000000).
Change the shape of the instrument panel
  • Click on the 'Scale with mouse' icon on the top, horizontal toolbar.
Now, when you select the cylinder, eight drag handles appear around the edges.
These allow you to reshape the cylinder by dragging on the appropriate handle.
  • Drag on one of the horizontal handles until the width of the cylinder is 120mm.
  • Drag on one of the vertical handles until the height is 60mm.
  • On the Panel Properties, set the depth (De...) to 3mm.
  • Centre the cylinder by setting its position coordinates to 'X'=0, 'Y'=0, 'Z'=0, on the Panel Properties.
Add the LED to the instrument panel
  • Now, move the LED back into position by selecting it and setting its position coordinates to 'X'=0, 'Y'=-60, 'Z'=0.
File:Panel Icon Group.jpg
Doing it in this order ensures that the LED appears on top of the instrument panel.
  • Drag over both objects, and group them by clicking on the 'group' icon.
Change the viewpoint
  • Flowcode allows you to view these objects from different directions by changing the 'camera position' (viewpoint.)
The first method uses the red, green and blue arrows at the top left hand corner of the System Panel.
First, click on the arrowhead of the green arrow.
This gives you a view of the objects from the 'green' direction.
Now do the same with the head of the red arrow, to see them from the 'red' direction.
Finally, clicking on the head of the blue arrow takes you back to the original view.
  • There are three 'camera' controls that give finer control.
File:Panel Icon Move.jpg
The first is the 'pan' control that allows you to move the viewpoint to one side.
To see this, click on the 'pan' control. Hold down the control (Ctrl) key, and click the mouse anywhere on the System Panel.
As you move the cursor up and down or from side to side, the viewpoint moves accordingly.
Notice that the coordinates of the objects do not change. The objects stay in the same place, but they are viewed from a different place.
File:Panel Icon CameraOrbit.jpg
File:Panel Icon CameraRotate.jpg
The second and third are 'camera rotation' controls.
Click on the first of these. Hold down the control (Ctrl) key, and click the mouse anywhere on the System Panel.
As you move the cursor, the objects seem to rotate, though, if you look at the 'Rotation' settings on the Panel Properties, you see that these settings do not change. Again, it is the viewpoint that is changing.
Then, try the same with the other control.
Multiple views
  • A powerful feature of Flowcode 6 is the ability to view the components from a number of different directions simultaneously.
File:Panel Icon GeneralOpts.jpg
  • To see this:
Click on the 'General options' icon.
In 'Number of views:', click on the down-arrow and select "3".
By clicking on the appropriate arrowheads, set up each view as shown below.
(Depending on the size and shape of the Systems Panel, the three views may be arranged vertically, instead of horizontally.
Drag one edge of the Systems Panel sideways to see this effect. )
File:Gen exerciseSystemPanelcontrolviewpoint threeviews 01.png
  • You can adjust the viewpoint individually for each view, by operating the 'camera position' controls.
An example of doing so is given below:
File:Gen exerciseSystemPanelshapecontrol multcamrot.png
  • Alternatively, you can make changes to the objects themselves, in which case all three views are affected at once.
In the next image, the grouped objects have been rotated:
What next
