API FCD.GetItemValue
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Gets a paths item value from the FCD document
Class hierarchy
FCD
GetItemValue
STRING PathName
The '.' separated path through the FCD to look in
STRING ItemName
The name of the item to read
STRING DefText
A default value to return if the item is not found
The default value for this parameter is: ""
STRING
Returns the paths item value from the FCD document
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::FCD.GetItemValue("pathname", "itemname", "deftext")
