API Scope.AddOverlays
<sidebar>API Contents</sidebar> Adds overlay packets to the stream by decoding the stream contents
Class hierarchy
Scope
AddOverlays
HANDLE StreamH
The stream that is to be read
LONG TimeUS
The -ve time offset to start the calculation from, in microseconds
ULONG Duration
The duration of the overlay packet
ULONG Baud
The baud to step through each sample with
ULONG Mask
A mask of any bits to include in a decoded packets format value
ULONG Flags
A set of flags to help decode the stream
Typical values for this parameter:
Name Description
Overlay_LSBF Flags least-significant bit first, else most-significant bit first
Overlay_Invert Flags to invert the bits in a packet before calculating the packet value
STRING LabelFmt
A format string to use for labeling packets
ULONG ForeRGBA
A red, green, blue, alpha value for the text and border
The default value for this parameter is: 0x000000C0
ULONG BackRGBA
A red, green, blue, alpha value for the area fill
The default value for this parameter is: 0x40FFE0A0
  • Add to a calculation icon:
    ::Scope.AddOverlays(streamh, timeus, duration, baud, mask, ::Scope.Overlay_LSBF, "labelfmt", forergba, backrgba)
