| Author
Matrix Ltd
| Version
8.0
| Category
Graphical Color
GLCD (GC9A01A SPI) component
Graphical display component designed to work with the GC9A01A controller IC Based on the GC9A01A 16-bit colour graphical controller IC. Uses the SPI CAL component to allow for faster serial display communications.
1, 2.0, 13-06-24, BR, Display Created
2, 2.0, 13-06-24, BR, Minor bug fix
3, 2.0, 13-06-24, BR, Minor bug fix
4, 2.1, 14-06-24, BR, Added round display property
5, 2.2, 22-07-24, BR, Added DrawArc and DrawRoundedRectangle functions
6, 6.0, 31-07-24, MW, Added an aditional font count of 4, making a font count of 8 in total
8, 8.0, 30-08-24, MW, all unused pins set to MOSI to avoid compiler error
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightOff
BacklightOff
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
| Draws an arc either as an outline or as a filled object.
- UINT
X
| Center X coordinate
- UINT
Y
| Center Y coordinate
- UINT
Radius
| Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
| Angle to start drawing, in degrees
- FLOAT
EndAngle
| Angle to end drawing, in degrees
- UINT
Resolution
| Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
| Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
| Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
| Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT
X0
| Start X coordinate
- UINT
Y0
| Start Y coordinate
- UINT
CX
| Control point X coordinate
- UINT
CY
| Control point Y coordinate
- UINT
X2
| End X coordinate
- UINT
Y2
| End Y coordinate
- UINT
Resolution
| Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
| Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Flip X
| Flips the horizontal display axis in hardware.
Flip Y
| Flips the vertical display axis in hardware.
Round Display
| Allows a round mask to be applied allowing a circular display to be simulated.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
| No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Queue Fast Pixels
| An optimisation for ESP32 based devices where Fast pixels are queued up and all drawn together. Acts to speed up writes to the display when drawing lines, rectangles, ellipses, circles, none transparent strings etc.
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
SPI Pins
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
Use CS
Toggle CS
| Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select
| Chip select pin connection
Use D/C
D/C or RS
| Instruction / Command pin connection
Use Reset Pin
Reset
| Reset pin connection
Use Backlight Pin
LED
| LED backlight strobe pin connection
Fonts
Font Count
Font 0
Font
Bytes Required
| Number of bytes required in program memory to store the selected font.
Character Spacing
| Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
User Label Text
| Text to display
Component Label Scale
Physical Orientation
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Please click here to download the component source project: FC_Comp_Source_GLCD_GC9A01A_SPI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_GC9A01A_SPI.fcfx
