Component: GLCD (E-BLOCKS 3) (Graphical Color)
Category Graphical Color
GLCD (E-BLOCKS 3) component
Graphical display component designed to work with the E-Blocks 3 colour touchscreen display.
Version information
20, 20.0, 02-08-24, MW, Added an aditional font count of 4, total font count of 8
23, 23.0, 28-11-24, MW, Fixed error trap for lines when y = 0
23, 23.0, 28-11-24, MW, Fixed shapes colour background  not working
23, 23.0, 29-11-24, MW, Fixed initial background colour not working
41, 41.0, 29-10-26, BR, SetExternalFont sends the font file to the web mirror (Load Font action Type 6), WiFi now connects before the fonts are set
BPlot
BPlot
- UINT X1
- UINT Y1
BacklightBrightness
BacklightBrightness
Adjusts the brightness of the backlight.
- BYTE Brightness
Range: 0 - 255, 0=Off, 255=Max
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- UINT StartAngle
Angle to start drawing, in degrees
- UINT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawBitmap
DrawBitmap
Draws a bitmap image loaded from the SD card FileInit must be called first to ensure the File System is setup.
- STRING Filename
Bitmap file to open from current directory on SD card 8.3 format
- UINT X1
X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT Y1
Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
DrawBitmapScaled
DrawBitmapScaled
Draws a bitmap image loaded from the SD card scaled to the defined width and height. FileInit must be called first to ensure the File System is setup.
- STRING Filename
- UINT X1
- UINT Y1
- UINT Width
The dimension to draw the bitmap in pixels
- UINT Height
- BYTE Orientation
- BYTE Transparency
- BYTE Flip
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawQRCode
DrawQRCode
- UINT X1
- UINT Y1
- BYTE Scaler
Size of each block in pixels: 1=33x33, 2=66x66, 3=99x99, etc
- STRING Text
Data to embed into the QR code. e.g. "www.myURL.com"
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
PrintFloat
PrintFloat
This macro prints a floating point number to the Graphical LCD.
- FLOAT Number
Floating point number to send to the display.
- BYTE NumDP
Number of decimal points
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SendBinaryAction
SendBinaryAction
Function to transfer the display manager edits through to the web mirror.
- STRING Data
SendBinaryScene
SendBinaryScene
Function to transfer the binary scene through to the web mirror.
- BYTE Data
Binary scene data
- UINT Length
Number of bytes to send
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetBitmapTransparency
Assigns the colour to use as the transparent mask. Anything in this specific colour will not be drawn when the DrawBitmap->Transparent parameter is set.
- BYTE R
Colour channel. Range: 0 to 255
- BYTE G
- BYTE B
SetDisplayOrientation
- BYTE Orientation
SetExternalFont
SetExternalFont
This macro overrides the default font with a substitute font file. The binary font file must be placed onto the SD card inside the Fonts folder.
- BYTE Font
Selects which Font to override Range: 0 to (Font Count - 1)
- STRING Str
Binary font file to use in standard 8.3 file format
- BYTE CharacterSpacing
Number of pixel columns added in between each character
- BYTE SpaceWidth
Number of pixel columns used for a space character
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
TouchCheck
TouchCheck
Checks to see if the screen has been touched. Returns 1 for a new valid touch and 0 for no touch.
- BOOL Return
TouchReadCoord
TouchReadCoord
- BYTE Axis
0=X, 1=Y
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Colour
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
EB3 Web Mirror
Allows display manager scenes to be forwarded to a web parser that can replicate the on screen display and touch system. Allows the display to be monitored and controlled via a web enabled device like a mobile phone.
Fonts
Font Count
Font 0
Font
Font Filename
Filename of font stored on SD card inside the Fonts folder
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
User Label Text
Text to display
Component Label Scale
Physical Orientation
Bitmaps Folder
Location containing the bitmaps for the simulation. $(scrdir) uses the Flowcode project directory.
Export Binary Fonts
Allows all selected fonts to be exported as a binary format that can be loaded from an SD card. When set to yes loops through all selected fonts and outputs .bin files into the project directory. May take some time to complete, resets back to no when complete.
Please click here to download the component source project: FC_Comp_Source_GLCD_EB3_MatrixCapTouch.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB3_MatrixCapTouch.fcfx
