Author
Matrix Ltd
Version
1.3
Category
Graphical Monochrome
GLCD (SSD1322) Parallel component
Graphical display component designed to work with the SSD1322 type monochrome displays. Compatible with 6800 and 8080 type 8-bit parallel displays.
Version information
BPlot
BPlot
- UINT
X1
- UINT
Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT
X
Center X coordinate
- UINT
Y
Center Y coordinate
- UINT
Radius
Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
Angle to start drawing, in degrees
- FLOAT
EndAngle
Angle to end drawing, in degrees
- UINT
Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Pixel_Colour
0=White, 1=Black
SetShadeIntensity
SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE
Shade
Range: 1-15 / 1=Dim / 15 = Bright
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Display Settings
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Interface Type
Sets the display interface type, this wil lhave to match the gLCD hardware setting.
CS
Chip select to address the first controller IC
R/W / Write
6800 - Read / Write Selection Pin 8080 - Write Enable Pin
Enable / Read
6800 - Enable Pin 8080 - Read Enable Pin
Data/Command
Data / Command selection pin
Reset
Display reset pin
Use Port
Controls if the data is sent via an 8-bit port, significantly speeding up writes to the display.
Data Port
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1322.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1322.fcfx
