Author
Matrix Ltd
Version
2.0
Category
Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT
X
Center X coordinate
- UINT
Y
Center Y coordinate
- UINT
Radius
Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
Angle to start drawing, in degrees
- FLOAT
EndAngle
Angle to end drawing, in degrees
- UINT
Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
DrawRoundedRectangle
Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastPlot
FastPlot
LCD_Write_Data8
LCD_Write_Data8
- BYTE
data
LCD_Write_Reg
LCD_Write_Reg
- BYTE
data
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Flip X
Flips the horizontal display axis in hardware.
Flip Y
Flips the vertical display axis in hardware.
Colour
Monochrome
Foreground Color
Background Color
Invert Colour
No: A set output will light the corresponding LED Yes: A clear output will light the corresponding LED
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Connection Type
Write (WR)
Read (RD)
Use CS
Determines if ther CS pin is used or is connected to ground and always enabled
Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Chip Select (CS)
Chip select pin connection
Reg Select (D/C)
Use Ports
Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Data0
Data1
Data2
Data3
Data4
Data5
Data6
Data7
Use Reset
Determines if the reset pin is used or if it is simply connected to VCC
Reset
Reset pin connection
Use Backlight Pin
LED
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_ILI9488.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ILI9488.fcfx
